86 f350 460 needs a radiator. The current radiator is a leaking plastic/ aluminum modine. I want to replace it with a copper brass 4 row #131 hd cooling. All but 1 place list this as only for 351. Is there a difference? Most 460 radiator #s are 1451. Why cant i find a brass/copper hd cooling for 460? Has anyone used a #131 for a 460? If i cant i will probably go all aluminum a few friends used champions with good results. The modine didn't cool very well even in its prime.
Thanks it's probably brain damage, naturally occurring though, i dont live near power lines. I really have looked alot, missed that one though. I see alot of back and forth over the aluminum vs copper/brass.
The current plastic rad is 3 years old. The plastic one before that cooled better but leaked from the same spot, middle of the plastic tank, not on a seam or edge, right in the middle.
