Radiator for 81 F-150 swapped in 460
I was wondering what radiator I should use for my truck I have an 81 F-150 so it's the top bolt on style not the side bolt. I am swapping in a 460 and want to get a bigger radiator. I was thinking about getting a 4 core for a 83 F-250/350 with a 460. I really do not want to go with an aluminum radiator a little to much money. Thanks if anyone could help
Are you sure that an aluminum radiator is the more expensive option as compared to copper/brass? Get yourself a good 4 tube Modine and you should be all set. 4 core should be more than enough radiator for that engine truck combination since I think that is the largest Ford put in as an option with their super cooling package. Aluminum with plastic tanks was introduced to reduce weight and cost. I'm not sure about the heat transfer comparisons of aluminum versus brass/copper but I would guess aluminum is not as good.
John
John
jonmammenga
07-15-2015 01:05 PM
F350moneypit
13
11-06-2013 01:32 PM
dyingtolive
19
01-31-2012 06:37 AM
