302 intake
Old Nov 10, 2017 | 08:43 PM
neelyjosh's Avatar
neelyjosh
302 intake
I have a 1990 302 HO from a Lincoln mark vii that I am putting in my 1984 f150 and I do not know if I need to buy an intake with a rear water crossover. The old fuel injected intake had a black metal hose running the length of the engine. Is that a rear water crossover. Thanks in advance
Old Nov 11, 2017 | 12:09 AM
Conanski's Avatar
Conanski
Are you removing the EFI intake and installing a carb? There is no rear water crossover on the EFI motors.
Old Nov 11, 2017 | 11:11 AM
Franklin2's Avatar
Franklin2
Carbed intakes bolt right on and do not have a rear water crossover. The only reason those ports are back there is because the heads can be swapped left and right. Make sure to use the right gaskets.
flipklos
31
Apr 23, 2010 11:34 PM
F-101
Apr 24, 2009 09:23 PM
97F250LD
Apr 12, 2009 04:08 PM
MARTINT
Apr 9, 2008 05:45 PM
vaughn
Jan 16, 2004 03:58 AM
