460 for towing
Old Nov 12, 2017 | 09:10 PM
Fastback460's Avatar
Fastback460
Originally Posted by Diesel_Brad
Yes any triton 05+ was 3valve and if the 5.4 could not keep up with the 460 then there is something seriously wrong with it
Well, it's been like this since we bought it 5 years ago. It runs smooth, no knocking/tapping, no leaks whatsoever, it's just slower then hell.
Old Nov 12, 2017 | 09:42 PM
Nothing Special's Avatar
Nothing Special
... or the driver just isn't using the powerband. Like I said, my '08 5.4 was gutless, but I didn't wind it out enough to get it in the powerband. I'd drop the ZF6 down to 4th gear at 70 mph. That brought it a little under 3500 rpm and it would at least not seem like the Bronco being towed was going to pass it. But I really needed to drop it down to 3rd, which would've brought the rpm up to 5500.
If I'd known what the power curve was on that engine I wouldn't have ordered it with the 3.73 gears it had. (Of course, if I knew what the power curve was I wouldn't have ordered the engine, or probably even the truck, at all.)
But the bottom line for this discussion is that it wouldn't surprise me if a TRUCK driver doesn't even get a 5.4L into it's powerband.
Old Jul 23, 2025 | 06:20 PM
Hunter92299's Avatar
Hunter92299
1st Gear
Originally Posted by BLK79
I use my 92 F250 460 4x4 to pull a 10K+ lb boat, and a lighter car hauler on occasion. Truck has over 270K on untouched engine, 3rd E4OD. It was an oilfield and later farm truck prior to me, I bought it when the 2nd trans was out.
It seems to pull best and be happiest in the 1500-2500 rpm range, which I like. Neighbor pulls a 7-8K boat to same location with an 06 GM 6.0. Loves the truck but hates the high rpm powerband.
Thank you you just solved a Chevy 6.0 vrs Ford 460 debate for me I had been offered both in a trade deal by two different people I'll be going with the 460 thank you.
Big460
Ford vs The Competition
196
Feb 1, 2026 05:14 AM
grm61
52
Jan 12, 2013 09:37 AM
Rudedude1
2009 - 2014 F150
23
Nov 7, 2011 05:06 PM
B411SAC
26
Jun 13, 2010 06:59 AM
GoneTulsa
Jun 30, 2003 11:35 AM
