I have a 1994 f150 with a 302 automatic. I just bought it and it has 107,000 miles on it. I am getting ready to change the oil in it and was considering using Mobil 1 synthetic oil. I want to know how long i can wait till the next oil change with the synthetic oil.
Also, i want to change the fluid in my transmission. I am going to do it myself and i want to know how much fluid i will be able to get out of it when i take the pan off. that way i will know how much to buy. I know it holds about 16 quarts but i know i cant get all of that out of the torque converter. Any help would be greatly appreciated.
on my vehicles i've run synthetic oil on 10,000 mile intervals, but at 5000 i change the filter, and top off the oil, with synthetic oil will out live the filter, so that why i change the filter at 5K and it only takes 1/2 to 3/4's of a quart to top it back off. I put over 100k on a new van with no problems till the day i sold it. DW
yup lots of converter have a drain plug, just remove the inspection plate and rotate the conver till the plug is at the bottom, remove the plug and let it drain. DW
my van had well over a hundred k on it when i sold it, it never leaked and i never added any oil between changes except when i change the filter, some vehicles are just gona leak, something are just gona break, but very seldom is because of the oil, or it didnt like that brand of plugs, or the motor blew up cuz it didnt like the water you put in the radiator, when are people gona learn, they are machines, sometimes they just break because. DW
Fossil oils over time swell gaskets and seals which is fine if they remain that way. Synthetic oil do not and over time when running synthetic after running fossil oils the gasket will shrink back to original size or even smaller causing leaks. It's not just a random thing it's a proven fact about syn. oils and fossil oils. Hope this clears things up.
Well i mean no disrespect here but I can not even begin to count the number of old tired worn out motor i've torn down to build into high performance street/race motors and when there were torn down the factory valve cover, intake, and oil pan gaskets were not swollen, they could not and were not capible of drawing up or shrinking because they were sqwished flat ,broken, craked, and extreamly brittle. with no pliability at all, any slight disturbace would cause a leak any where there wasnt already one. but i not gona buy (well my neighbor put that stuff in his car and it leaked so that must be what caused it) theres tons and tons of info on the web saying this does that, and this dosent, but we have to decifer whats the truth/facts and what someones biased opinion. sorry ive done it in numerous cars of my own the van was just one,i dont buy it, so far i havent been able to back that theory up thru my experience and havent seen a proven data sheet that didnt come from someone with somthing to gain from it. DW
