I'm trying to install LED light bar under the tailgate and when I took the tailgate off there was a little bracket bolted to the back of the bed with a slot for a tab that is on the tailgate itself, it's on the right side. what is the purpose to it? it's in the way of where the light bar goes!!
I`m not sure what it`s for but i`m sure it`s there for a reason which more than likely, is a feature or an option that`s available for your year and model of truck but is part of a different trim level.
No, it`s not in the way of where the light bar goes because the light bar is not an OEM part that came on the truck as standard equipment or as an option.
With that being said, you can always just cut it off.
