Sponsored by: Real Truck
MAS?
Old Nov 9, 2017 | 05:28 PM
Patch Gall's Avatar
Patch Gall
MAS?
My V-10 is hard starting. Takes 8-10 cranks to get it going. It starts out with low rpms, but then goes to normal idle Once it starts, it idles smooth. Once at running temp, it still runs smoothe. If I ease on the the throttle, no problem. Rpms go up without a miss. If I floor the throttle there is a hesitation for a second or two, rpms climb normally. This just happened all of a sudden. Air cleaner is stock and clean.
Old Nov 9, 2017 | 05:38 PM
Just Strokin's Avatar
Just Strokin
Have you checked to see if any stored coded in the PCM? If you do not have a code reader, go by one of the chain parts house and asked them to pull the codes for you.
Old Nov 10, 2017 | 10:14 PM
Djosbun's Avatar
Djosbun
Need more info to help troubleshoot. What’s the mileage? Has truck been maintained as required?
Hesitation can be difficult to track down. Best to start with the cheap and easy stuff. First is to check for vacuum leaks. Vacuum hoses become brittle due to heat cycles and age. Check for cracked hoses or missing connections. Buy a can of starting fluid and spray it around the vacuum lines, one section at a time. If revs change, you found your vacuum leak. Replace the hose and see if hesitation is gone.
— Dave
Old Nov 11, 2017 | 07:07 AM
projectSHO89's Avatar
projectSHO89
It's unlikely to be the MAF sensor.
Usually doesn't work on these engines, the PCM is too fast an you'll never hear any difference.
Extended cranking times is usually associated with a weak fuel system (which would also cause hesitation upon sharp acceleration). A fuel pressure gauge is recommended for diagnosis, depending on the year of the truck.
Old Nov 11, 2017 | 08:26 AM
5_labsownus's Avatar
5_labsownus
As indicated more information on the truck would be great. As projectSHO89 said this is indicative of a fuel delivery problem. Proper diagnostics are indicated and any stored DTCs would help.
Rod
Old Nov 11, 2017 | 09:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
What year is this V10?
Have you hooked up a code reader yet? What are the fuel trims at idle?
landyaght
Modular V10 (6.8l)
Aug 21, 2021 08:14 PM
SomeDude451
Sep 1, 2014 09:16 PM
Nighteyez
1978 - 1996 Big Bronco
15
Feb 5, 2014 09:48 PM
lazykranch
1983 - 2012 Ranger & B-Series
Dec 6, 2009 10:25 AM
ranger714
Aerostar
Mar 4, 2009 03:01 PM
