Sponsored by: Real Truck
4x4 switch not working
Old Nov 8, 2017 | 06:47 PM
Kennicol's Avatar
Kennicol
When I turn my switch on to turn on four wheel it doesn't come on neither does the four wheel drive. Any way to check the switch worked month ago for my grandson. I did run it thru the carwash that that did an under body wash. Could that have messed something up
2001 f250 v10
Old Nov 8, 2017 | 10:21 PM
maticuno's Avatar
maticuno
Check fuse 19 and 111 in the fuse block under the dash.
Old Nov 9, 2017 | 03:30 AM
seville009's Avatar
seville009
Check the wires/plugs/connections under the truck into the 4wd shifter motor.
Old Nov 9, 2017 | 08:42 AM
Copper.Farm's Avatar
Copper.Farm
Also, Check for a vacuum leak in the lines between the hubs and the intake manifold or vacuum pump.
If you don’t see the dash light up within a few seconds of flipping the switch, then as others have suggested electrical or the actuator on the transfer case.
Gousetis
Oct 23, 2016 04:40 PM
02 Super Duty Guy
Sep 21, 2013 08:08 AM
trim man
Mar 5, 2009 07:45 PM
riggz
Oct 13, 2007 10:47 AM
SpareTime
Dec 15, 2005 10:09 AM
