1978 - 1996 Big Bronco
dead bronco
Old Nov 8, 2017 | 10:01 AM
pnutbailey's Avatar
pnutbailey
dead bronco
I have a 1980 bronco with a 351. this morning it cranked and ran fine. i shut it down and came back 30 min later and.........nothing. no lights no click from solenoid no radio no fan. the voltage on the battery is 12.6. jumping out the solenoid has no result. ground to engine block and to cab both read fine. i have voltage at the fusebox. if i jump out the s and i terminal on solenoid i get battery voltage running through it. what am i misssing?
Old Nov 8, 2017 | 10:48 AM
Jklnhyd's Avatar
Jklnhyd
It is not in Park.
Apply the brake, shift down to first, then back up to park, then start the truck
Nvm, i didnt read it all, I am driving, lol
Old Nov 8, 2017 | 11:50 AM
pnutbailey's Avatar
pnutbailey
checked allready. i cranked it this morning just fine just let it sit and warm up. shut it off and came back 30 min later and nothing
Old Nov 8, 2017 | 11:52 AM
pnutbailey's Avatar
pnutbailey
i have fog lights that i can turn on even with no key in ignition and they wont even work
Old Nov 8, 2017 | 12:26 PM
pnutbailey's Avatar
pnutbailey
voltag+e to solenoid ignition off , 12.5 input nothing on the other side or the start. with ignition on i get 12.5 on input , 10.3 on output and start.
Old Nov 8, 2017 | 01:02 PM
pnutbailey's Avatar
pnutbailey
ok. update. re read voltage as described above and have same on input and output and start. checked voltage after fuseable link on the thick yellow wires. 12.5volts. checked fusebox and have 12.5 volts on only 1 unused slot with ignition off. with ignition on i have nothing in fusebox
Old Nov 9, 2017 | 11:24 PM
Torky2's Avatar
Torky2
With key OFF, do you have a dome light with door open?
With key OFF, do headlights work?
Ncrumpton
Nov 20, 2017 10:00 PM
77f150c
Mar 5, 2014 10:21 AM
BRONC-OH
1983 - 2012 Ranger & B-Series
Apr 1, 2012 03:16 PM
MonsterBroncoKid
Nov 3, 2004 08:08 AM
kluelessjo
Bronco II
Aug 30, 2003 06:50 PM
