5.4 Triton broken stud removal
Like they said,....usually the stud will come out fairly easily.
If the stud has some meat sticking out I use a Sears Craftsman stud remover. Always works.
Craftsman 0350CCRA 6-Piece Bolt-Out Set | Sears Hometown Stores
If the stud is broken off flush or under flush, use some penetrant and try to manually turn it out with a pick or similar tool.
The studs typically break due to corrosion on the stud shaft in the manifold area, not from binding in the threads.
Welding a nut to the stud is the method of last resort.
I've used a small nail with a extra small drop of gel style crazy glue on the head. Hold it to the stud until it sets, leave it for an hour or so then try and back it out easy. Just use a tiny amount of the glue, you don't want it running into the threads. I use the gel style because it's less likely to run.
TheRooster
01-11-2017 09:03 PM
fredweberjr
1999 to 2016 Super Duty
03-16-2008 07:08 PM
