Sponsored by: Auxito
Radio
Old Apr 6, 2017 | 07:47 PM
pastorbruce's Avatar
pastorbruce
Radio
I have the original radio in my 2003 f150 equipped with a cassette player. I am wanting to replace it with a CD/ radio from a scrap yard. What other years and/or models would be an exact fit?
Old Apr 7, 2017 | 10:40 AM
Darksideforge's Avatar
Darksideforge
The stock replacement single CD player will need to be from one of these:
If you want the in-dash 6-CD changer you'll need it from one of these:
I'm not going to bother (at this point) giving you the interchange information for a center console-mounted CD changer because that would involve you removing one (that still has a CD cartridge in it) and also removing the wire, connector, and mounting hardware from a donor truck and installing all of it on your truck.
Hope this helps. ~dsf
Old Apr 7, 2017 | 10:43 AM
Darksideforge
Generally speaking, with the exception of the aforementioned wiring harness issues related to the remote CD changer in a center console, the radios/cassettes/CD's are interchangeable in any 97 thru 2003 F-series truck and in early 2004 (Heritage Edition) trucks. This does NOT apply to Lightning model F-series trucks as they had aftermarket-equipped sound options.
Old Apr 7, 2017 | 10:45 AM
Darksideforge
Many scrap yards will already have the stereos pulled out and stored on a shelf somewhere. In those cases you can actually look at the factory sticker on the top of the unit and compare the ID numbers as shown above.
Old Apr 7, 2017 | 11:55 AM
pastorbruce
Thanks, that helps greatly.
Old Apr 7, 2017 | 12:15 PM
sam hain's Avatar
sam hain
I'd be interested in buying your radio if everything works. Mine works but the display don't work so I can't see the station or the time.
Old Apr 7, 2017 | 02:42 PM
pastorbruce
Everything works, even the cassette player. Just stock radio. I want something that looks like it was always there. I'll let you know if I can find one.
Old Apr 13, 2017 | 09:40 PM
TruckinAL's Avatar
TruckinAL
I have a cassette head unit, 6 disc changer that sits behind the seat ( reg cab) on the right side the wiring harness the whole set up . Make me a reasonable offer everything works
Old Apr 13, 2017 | 09:42 PM
TruckinAL's Avatar
TruckinAL
All from a 99 F-150
Old Dec 16, 2017 | 06:27 AM
60DRB's Avatar
60DRB
Darksideforge,
Thanks for the information. I'm about to replace my brother-in-law's factory AM/FM tape player (2001 XL) and wanted to simply replace with the factory CD upgrade. The stock numbers you list are helpful.
Would I be correct to expect the stock wiring & plugs to match/fit between the listed units?
Greg
Old Dec 30, 2017 | 06:52 AM
Darksideforge
Greg,
The plugs themselves will almost certainly fit....whether or not you will get full functionality is another question. It will depend on how many speakers your XL came equipped with and whether your original harness is equipped with power in the right place to power the CD player...but it SHOULD be plug-and-play.
Old Dec 30, 2017 | 10:10 AM
Chad T. Keogh's Avatar
Chad T. Keogh
My stock AM/FM/CD player was not playing CDs and sounded horrible anyway. I replaced the deck with a Kenwood AM/FM/CD with Bluetooth. I put in an adapter plate with a small storage shelf below the deck and 4 5X7 4-way Scosche speakers. Did it ALL for about $200CDN. Now I have stereo sound worthy of such a good truck.
I didn't have to do any cutting or modifications. Just remove and replace.
dmorrill22
Jul 24, 2016 02:42 PM
BRONC-OH
1997 - 2003 F150
Mar 15, 2016 10:14 PM
yooperbill
Jan 14, 2008 08:10 PM
balingwire
1997 - 2003 F150
Jan 16, 2005 07:16 PM
AKESPY
Apr 26, 2004 05:25 AM
