Fuel pump testing from selector valve
Old Nov 7, 2017 | 05:42 PM
Edward Michael's Avatar
Edward Michael
Any guidance on testing in tank fuel pumps from the selector valve.
Which pins are hot to front and back pumps?
12 volts?
5 pin connector at selector valve.
Truck is 85 F350 2wd crew cab longbed with 460 and manual 4 speed.
Thanks.
Old Nov 7, 2017 | 07:00 PM
Franklin2's Avatar
Franklin2
The wires at the selector valve on the frame are for the sending units, not the pumps. The pumps were switched two different ways or versions. One version switched the power directly from dash switch. The other version switched them through a relay over by the booster. If you have two relays over by the brake booster, one will be the pump select, the other will be the pump relay activated by the oil pressure switch. If you only have one relay, then you have the version where the pump select is by the dash switch.
hbphc34
Sep 1, 2014 10:57 AM
clintbdu
May 13, 2014 04:42 PM
mort2000
Aug 19, 2009 06:31 PM
lowrider400ex
Jan 22, 2009 05:39 PM
lrd56
Apr 19, 2007 11:20 AM
