Fuel pump problem
Old Aug 31, 2014 | 06:57 PM
hbphc34's Avatar
hbphc34
Fuel pump problem
F250 1987 4wd 460ci carburetor. Have power to front pump no power to back pump. Need help to figure out problem. Could it be the dash switch or the valve on the frame? Only have two low pressure pumps and the front one has power back one not. Wiring issue? Relay issue? Driving me crazy I have bypassed the oil pressure switch so I can get power to the pumps with the key on for testing just need to know where to start.
Old Aug 31, 2014 | 07:30 PM
subford's Avatar
subford
The power to the pumps comes from the selector switch on the dash. So the valve has nothing to do with the power to the pump in the tank.
Old Aug 31, 2014 | 07:43 PM
hbphc34's Avatar
hbphc34
Thanks for the response... don't the wires on the valve run each pump depending on switch location or is the valve just switched by pressure from the pump? It looks like the wires to the valve come in and then back out to each pump.
Old Sep 1, 2014 | 06:43 AM
subford's Avatar
subford
No, the wires from the valve to the tank are just for the fuel gauge.
Pressure from the tank pumps has nothing to do with any switching. The valve has a motor in it that is operated by the switch on the dash. When the motor runs it switches tanks and the circuit for the fuel gauge.
Out wires just go to the fuel gauge senders in each tank.
Old Sep 1, 2014 | 10:57 AM
hbphc34's Avatar
hbphc34
Thanks for the diagrams. I will investigate further and let you know what I found
Edward Michael
Nov 7, 2017 07:00 PM
WeldorJP
Feb 23, 2013 06:47 AM
cityjack
Mar 17, 2012 02:05 PM
smsperformance
Dec 5, 2009 04:12 PM
55-willys
Jul 7, 2003 06:45 AM
