Charging system/alt/batt question
Anytime a battery drops below 10v for extended periods of time it receives damage. The coating on the inner plates begins to flake off reducing its ability to put out power. You would still see 11-12.6v fully charged because that in no way reduces its ability to store electricity (until there is no more coating anyway). But with the reduced surface area of the inner plates, the amperage drastically reduces.
Optima Blue Tops have thicker coatings with less surface area - Can take more damage from power loss, but has less amperage as a result. Good for applications with power usage without constant charging. RVs, Boats, etc.
Optima Red Tops have a thin coating with a lot of surface area - Easily damaged by power loss, but have excellent amperage readings. Good for applications that require a lot of power but also is constantly charged or charged immediately after usage. Starting an engine, high power audio equipment, welders, etc
Optima Yellow Tops are a best of both worlds solution, meaning they are like a standard car battery, but with the resilience of a dry cell. Winches, offroad lights, cars that sit, etc.
If yours sits for a long time I'd go with a yellow top and a lever style battery disconnect on the ground side. Disconnect it while it sits. No power loss.
Also with Optimas, always check the date of manufacture before purchase. They tend to sit on shelves for a VERY long time due to their price tag. A 2yr old battery can actually be 5yrs old. My local Advance Auto store has a blue top on it's shelf from 2015.
If the engine can not run without the charger then the alt isn't producing enough power to keep the truck running. I can disconnect my battery while the trucks running and then drive around town with ZERO issues. I've done it to win bets several times. I would take the alternator to your favorite parts store and have it tested. If it comes back okay then replace the regulator. Personally, if I had any doubts I'd replace them both.
Since you have all the parts, replace them all at once. Might seem like a waste but it's not IMHO. A bad starter kills a battery, a bad battery kills an alternator, a bad alternator kills a battery, a bad battery kills a starter. They are all dependent on another. I worked at Autozone for a time I can tell you that the three typically fail together if one of them fails and is ignored.
The smell of gas could be because you kept trying to start the truck without spark and flooded the cylinders. Take out a spark plug and check them for fouling. OR it could be a carb float issue, the bowls could be over filling.
I have no experience with MSD personally but if you're worried about it firing or not, take out off a plug lead, shove a screwdriver in it and hold the screwdriver close to the engine block while starting the truck. A spark should jump from the screwdriver to the block. Poor man's test, my favorite way to do it.
Another way is to pull the spark plug as well. Plug it into the lead and touch the threads to the block. The spark plug should spark when you try to start it.
If the smell of gas is strong though I'd set up a small fan to blow on the engine beforehand. Wouldn't want fumes to ignite.
Other than that check the basics. Look down the carb, pump accelerator, does gas pump into the carb?
Yes? Then you have fuel. Don't go off, "I smell the gas" it could be dumping out on the ground and that's why you smell it. Make sure it's getting in the engine.
No? Disconnect fuel filter that's before the carb at it's inlet, turn the engine over, does gas come out? Yes? Then filter is clogged, replace. I've seen clogged filters build pressure and leak at the inlet. Smells like gas and makes you think it's getting gas, but it's not.
No gas came out? Possibly a bad pump. Disconnect inlet from the pump. attach a hose and put in a container of gas. Turn the engine over, is the gas coming from the outlet? No? replace the pump.
Gas does come out? Possibly a clogged fuel line. Could just be your out of gas (happened to me, was having a bad day). Could be that your fuel pickup rusted in the tank and fell off (also happened once, VERY bad day).
The batt was a blue top, not yellow top, and I had a spare one. Took alt off and had it checked. It was good, so reinstalled it. Put on new voltage regulator just cause. Still nothing. So either MSD or fuel pump is bad. I guess all that rust could of gotten pump, but I would of thought prefilter would saved it. Waiting for assistance to check pump and then I’ll check MSD if necessary. Oh yeah, truck is aftermarket efi, so needs like 42-45 psi to fire injectors. No fuel leaks, it’s on a concrete pad.
Ignition problems could be the pick up in the distributor or the control box or the coil. You can test the coil with an ohm meter.
If the truck is making spark, then you'll want to check for fuel. First make sure the pump is coming on and making pressure.
If fuel pressure is OK, then you're going to need to test the EFI system. I don't know how this is done. Hope you still have the instructions... But I can't imagine they'd sell an EFI system without provisions for a system test, like OBD1 and OBD2 systems do.
Prop your hood open and connect a multimeter to the battery. Place it so you can see the reading while the engine is cranking. Watch the reading as you crank - you will ideally see 11v or more. 12v is the ideal scenario. Anything under 11v and the EFI will have trouble. 10v or less and even points will have trouble firing the engine.
Doesn't have to be a $50 multimeter either, anything will work so long as it gives anything close to accurate readings. I have a few cheap dollar store ones so I can keep one in my go-bag, one in the car and another in the shed.
- boingk
1. Ohm out the stator (AKA pick-up coil). Disconnect the three prong terminal form/at the distributor. Measure the resistance between the ORANGE and PURPLE wires (making sure the spade terminals are clean and un-boogered). You want to see between 400 and 700 ohms. Any more/less, replace the stator. The BLACK wire is a distributor ground and should not show any reading...or a very minute reading in ohms or a good continuity check to ground.
2. Key ON engine OFF....measure the voltage between the BATT (+) terminal on the coil and a good clean ground. You want to see 6 - 9 VDC. This is the ballast resistor wire....if it's shorted or open, the vehicle won't stay running. This circuit is bypassed in START...allowing the full battery voltage (momentarily) to the coil.
. Hope not too much damage was done?If that ballast resistor wire goes too long without being fixed/replaced it could also be the cause of the coil goin' south. They get fried if ran on 12 VDC for too long as the OEM coils (as well as most after market ones) were meant to run on 9 VDC....or less.
