trans swap question
Old Nov 5, 2017 | 03:29 PM
lakequ's Avatar
lakequ
trans swap question
on so i have a 1997 ford f250 heavy duty 5.8 e4od with a blown trans and i found one out of a f350 with the same engine will it swap over??
is there any differences between a 250 and a 350??
thanks in advance
Quinten lake
Old Nov 5, 2017 | 04:23 PM
rla2005's Avatar
rla2005
There is no difference in the transmissions given a few specific details (year, 2wd or 4wd).
First question: Why do you think you have a bad transmission? plenty of threads where folks changed the transmission then still have the same problem.
Second question: Assuming you really do have a bad trans., what year is the donor F350?
Old Nov 5, 2017 | 06:58 PM
lakequ's Avatar
lakequ
i know i have a bad trans because the guy before me ran it with low to no fluid and it smells burnt when you pull the dip stick.
The donor is a 1995 both are 5.8 2wd e4od
Old Nov 5, 2017 | 07:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
This is a direct bolt in.
Old Nov 5, 2017 | 08:13 PM
rla2005's Avatar
rla2005
X2....on Mark's post.
Old Nov 6, 2017 | 06:55 AM
lakequ's Avatar
lakequ
ok thanks for the help guys
TheProfessorofTOOL
1997 - 2003 F150
Mar 29, 2015 01:29 PM
mudbogger93
May 7, 2012 10:12 PM
jo7.3idi
58
Jan 20, 2009 07:24 PM
