Sponsored by: Kumho
97 E-250 brake issues
Old Nov 5, 2017 | 03:29 PM
chipper's Avatar
chipper
Just got done with a major project. Swapped a rust free 2000 van body onto my 1997 E250 Guigley 4x4. Having a problem with the brakes.
First it has all new brake lines, steel and rubber. New calibers, cylinders and pads. Been vacuum bled a couple times and ole fashion manual bled a couple more. Brake pedal is nice and firm and NO lights of any sort are on. Brakes worked great before swap so the rotors and drums are fine. Have adjusted the rear brakes several times lose to tight, no change. Also changed the rear axle sensor.
Problem is the rear brakes are locking up and there is some vibration/shudder. When first starting out and it's cold it's not as bad. After driving 4-5 miles and using the brakes several times it slowly gets worse. To the point of rear drums getting hot and locking up when brakes are applied. Let it sit a few hours and it's fine again and will redo the same thing.
The shudder/vibration is in the rear, whole van shakes. No pulling, shake or vibration from the steering wheel or pedal. What am I missing here??
Old Nov 5, 2017 | 04:32 PM
KULTULZ's Avatar
KULTULZ
Post
Something (hydraulic/mechanical) is holding the rear brakes on.
Drum or disc?
Old Nov 5, 2017 | 05:10 PM
chipper's Avatar
chipper
Disc in front and rear drum.
Took it out and pulled the fuse to disable the anti lock BS. No change.
Did check the front and they are working. Went out in the field and stomped on the brakes. Rear locked going forward and front skidded a little in reverse.
Forgot the emergency brake is disconnected also.
Old Nov 27, 2017 | 04:59 PM
chipper's Avatar
chipper
Turned out to be a bad anti lock brake module. I hate it when people don't follow through with a thread.
Old Dec 29, 2022 | 03:31 PM
Rolling Toolbox's Avatar
Rolling Toolbox
1st Gear
Chipper, thank you. I'm having the same problem with my 97 e250. It seemed to be the self adjuster cable because it's come off a few times but now I suspect either the wheel cylinder or the anti lock brake module based on your post. My code reader used to read the ABS codes on my van now it says it can't detect ABS, was that the case for you as well when your module was bad?
76F100guy
Sep 26, 2013 10:46 PM
Spotty
1997 - 2003 F150
Dec 17, 2009 02:09 PM
CK5
1997 - 2003 F150
Jun 8, 2008 02:01 AM
Mud Bone
Feb 18, 2006 07:31 PM
