Oil Wear Protection Info
Hello all. I've posted this blog article in other sub-forums on the site but I thought I should post it here too. It seems to be an independent testing on several different oils, synthetic, blends, conventional, diesel and auto.
According to 540 Rat, he tests on wear and shearing in strictly a PSI to fail rating. I don't know anything about 540 Rat but it seems that his testing methods are nothing short of a consistent industrial experiment. Here is the article. https://540ratblog.wordpress.com/201...-test-ranking/
He also has a Q and A portion that he will answer questions from anyone.
Justin,
I was going to post the same link but thought I'd search first. Sure enough, you beat me to it. Hard to believe you haven't had a response yet. Lots of very interesting information at 540 RAT's blog. The most surprising result of his testing is that in general oils designed for Diesel truck engines provide less wear protection than oils for gasoline car engines.
so the link is an interesting read....and certainly focused on the 30 weight market.
one of the problems I have with these types of studies is that if you say this particular link uses test type #1 and my favorite oil scored 40 out of 80....then look at 20 other test methodologies...my favorite oil will move up and down on the rankings depending on what the test method is......so we have yet to find a test method that identifies the "super oil" at any price.
not to much rotella representation on the rankings which is a very popular oil.
but this was a good read...thanks for posting
Hypoid
63
02-16-2007 02:13 PM
Beachbumcook
09-29-2006 08:29 AM
