Decode - Rear
Old Nov 4, 2017 | 06:37 PM
Boostingaz's Avatar
Boostingaz
Decode - Rear
Can anyone decode the following:
6 5.3
6M19
DIF 48 (Maybe a 49?)
Another 6M19
C5AW
668(or S)A
Thank you in advance for the info.
Old Nov 4, 2017 | 11:34 PM
ultraranger's Avatar
ultraranger
Doesn't mean anything about the ratio or type of differential inside that 9-inch 3rd member. The alpha-numerics are simply engineering casting numbers and dates when the case and the pinion support housings were cast.
Originally, there would have been a tag affixed to one of the (10) studs that holds the 3rd member to the rear end housing. This tag would have contained the information about the differential type and the gear ratio. If the tag is missing, it means someone has removed the 3rd member from the housing at one time but, didn't bother to put the tag back on before tightening all (10) of the nuts.
The only sure way to know what differential type is there and what ratio it is would be to remove the 3rd member and visually identify what's in there.
If you do take the 3rd member out but don't know an open (single track) differential from a Traction-Lok, you can post a photo of it and I can identify what it is.
As far as determining the ratio, all you have to do is count the number of ring gear teeth and the number of pinion gear teeth. Divide the number of ring gear teeth by the number of pinion gear teeth and that will give you its exact ratio --none of this lift up the rear end, count the number of driveshaft revolutions vs. wheel/tire revolutions. That method can easily be inaccurate. Actually counting ring & and pinion teeth is fool-proof with no margin of error or guessing and the result will be exact.
Old Nov 5, 2017 | 01:54 AM
351Cleveland C4's Avatar
351Cleveland C4
Yep.......
Old Nov 5, 2017 | 09:11 AM
Boostingaz's Avatar
Boostingaz
Thank you. Next question: How does one go about checking fluid level / filling if necessary?
Old Nov 5, 2017 | 09:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on the 2nd line-far right of the Warranty Plate, riveted to the left door face below the latch.
Post what the code is.
6M19 = Axle assembled December (M) 19, 1966 (6).
Old Nov 5, 2017 | 09:40 AM
Boostingaz's Avatar
Boostingaz
From the door tag, Axle: 09
Old Nov 5, 2017 | 09:43 AM
ultraranger
Fill/sight plug will be on the left side of the 3rd member.
NOTE: Early 9-inch 3rd members didn't have a fill/sight plug on them. The plug would have been on the backside of the rear end housing (pre-Bumpside era). Later 9-inch 3rd members have the plug on them and no plug on the back side of the rear end housing (from later into the Slick era through the Bullnose era).
"DIF" is where the parts were cast: Dearborn Iron Foundry.
The code on the warranty plate may correctly indicate what is presently inside the rear end housing and, it may not. If the I.D. tag is missing from the 3rd member, good chance the 3rd member has been taken out of the housing. Gears could have been changed, differential type could have been been changed, even the entire 3rd member itself could be something different than what the truck originally came with.
Old Nov 5, 2017 | 09:46 AM
ultraranger
09 = 3.70:1, 28-spline, open (single track) differential.
Old Nov 5, 2017 | 10:00 AM
Boostingaz's Avatar
Boostingaz
Perfect, I will have to look when I get that side cleaned up better, there was like 2" thick of mud/gunk covering the entire rear.
Here is the back side of mine after some cleaning:
Old Nov 5, 2017 | 10:22 AM
ultraranger
Is this a '67 model truck? I see a fill/sight plug on the back of the housing --towards the lower right side.
Old Nov 5, 2017 | 10:35 AM
Boostingaz's Avatar
Boostingaz
Just got home and crawled under for a look:
Yea it ia a 67' "on paper", but I'm starting to figure out that the f in f100 on mine must stand for Frankenstein. As I also have a 71' engine running a 68' distributor hmm.
Old Nov 5, 2017 | 11:16 AM
NumberDummy
09 = Ford 9" Rear Axle / 3.70-1 / 3,300 lbs. Axle Capacity.
Old Nov 5, 2017 | 01:21 PM
Boostingaz's Avatar
Boostingaz
Perfect! Much appreciated.
David LaPell
Sep 21, 2010 06:22 AM
hairyboxnoogle
Mar 16, 2010 03:30 PM
385seriesHemi
Mar 14, 2006 02:25 AM
hoxiii
Mar 24, 2005 11:32 AM
rig_pig30
Sep 2, 2004 06:29 AM
