Signal Problems
Old Nov 4, 2017 | 04:35 PM
FlyingHellfish's Avatar
FlyingHellfish
Signal Problems
Turn signals started failing. When the switch was engaged it would take a second for the signal to flash. Now no signals. Hazards work fine. I replaced the Signal Switch, Flashers, and checked the bulbs. Still no turn signals. What next? I'm sure I need to check continuity on the wires, but where do I start?
Old Nov 4, 2017 | 08:11 PM
Filthy Beast's Avatar
Filthy Beast
Welcome to FTE.
97% of all electrical problems are grounding issues.
First, verify you have power to the pigtail in the light socket. A test light is perfect for this.
If you have juice, check for continuity between the socket's side walls and a good, clean ground. The bulb gets its ground through the metal sides of the socket.
Continuity to ground?
You could stick the bulb back in and wiggle it to check if it lights up. Sometimes the sockets and/or pigtails get worn out and need replacing.
Old Nov 4, 2017 | 10:31 PM
FlyingHellfish
The brake lights and hazards work so I know the socket is working right?
Old Nov 4, 2017 | 11:51 PM
FlyingHellfish
FOUND IT. Loose connection from flasher relay to signal switch connection.
Old Nov 5, 2017 | 08:20 PM
1976F350campspecial's Avatar
1976F350campspecial
good job thanks for posting up repair
Emmett Wester
Mar 30, 2017 01:20 AM
Trapper76
May 12, 2016 11:41 AM
Adam Woolridge
Dec 7, 2015 04:31 AM
hacking_in2002
Jun 12, 2009 09:36 PM
ranger714
Dec 13, 2004 12:06 AM
