tuning question
Old Sep 10, 2003 | 11:06 PM
94matt's Avatar
94matt
tuning question
Hi guys,
Today the old girl hit the road for the first time in many years. For the most part it was uneventful, the turn signal doesn't have any detents left but the was pretty easy to watch. Now, when I would stop somewhere for a few minutes it was hard to start back up. It turned over fine, but needed to crank for a while before firing. When it's cold it fires right up. Any ideas what can cause this?
Thanks,
Matt
Old Sep 10, 2003 | 11:09 PM
MudinMan19704x4's Avatar
MudinMan19704x4
tuning question
last time mine did that the starter was geting to hot from the headers and then went out the next day .....
Old Dec 8, 2003 | 10:30 PM
stgdive's Avatar
stgdive
Its' good and choked when it's cold and the fast idle ajustment is is ingaged. They're cold blooded and take awhile to get to normal operating temp (mine does anyway 67f100/352). but when that fast idle and choke are dropped out(if it's a heat tube type)
because the engine is nice and warmed up. On mine anyway, i have to rely on pumping the gas a bit. I would suggest checking the idle mixture ajustment, the fast idle ajustment, and the curb idle ajustment. Your fast idle may be set low and when it drops out, there may not be enough curb idle to start it when its warm.
A few suggestions anyway. Timing is a factor also. I set mine at 6deg btdc at 550 rpms(curb idle) with the vacume pulled off the dist..
Old Dec 9, 2003 | 12:28 PM
Freightrain's Avatar
Freightrain
Check the overall tune up like mentioned.
As for hard re-starting. Mine was like that this past summer. When it gets warm out, and I shut it off. It like boils the gas out of the carb and then it takes a few seconds til it finally starts again. It runs flawless, but it did have this problem. I did put a new Holley 4bbl on it, so I should not have that problem next summer(plus I put an insolator plate under it to keep the heat off).
The turn signal switch is an easy fix.
Glad to hear your trip went well. They're old, but I drive them anywhere!
Larry
Old Dec 9, 2003 | 06:29 PM
aoldford's Avatar
aoldford
My truck has done variations of this for a long time...sometimes seems like flooding. I've heard other suggestions in the past about spacers to insulate the carb from heat build-up. Sometimes dirt will get into passageways and jets (especially after sitting for awhile). The heat causes higher pressure and some leaks past the not quite closed valve/jet. I just hold it at mid throttle and crank...always starts. Just a couple of thoughts. Good Luck. Check the float, too. Joe
Old Dec 10, 2003 | 07:47 AM
jeremyd72's Avatar
jeremyd72
Matt,
I'm not sure if you have fixed it yet, but it sounds as if your choke is staying on too long. Mine did that before. If I stopped anywhere after the engine was warm it was hard to restart because it was flooding. Since you only stopped for a few minutes, it shouldn't cool down enough to need the choke again unless it is extremly cold.
Jeremy
Old Dec 10, 2003 | 06:36 PM
94matt's Avatar
94matt
Well, I have tried everything I can think of. Timing is at 10 degrees, new timing chain, carb rebuilt, new plugs, wires, etc., etc.
I have given up on this carb. While visiting my parents over Thanksgiving, my Dad gave me a 4 bbl intake he had lying around. I have been trying to find a carb for it since, but haven't had much luck. I tried E-bay first, but got discouraged pretty quick. Right now, the old Ford sits and I am waiting to hear from my neighbor who has a lead on an autolite and a holley 750 for me. I am anxious to get back to driving the Ford and have also rounded up the power steering conversion parts to put on when I swap the manifold.
Just trying to get a carb right now
Matt
Apocalypse
Jul 19, 2016 06:17 PM
VolvoMatt
Jul 4, 2016 09:52 AM
orange57
Jan 22, 2016 11:37 PM
turtlespeeder
Dec 24, 2015 10:44 AM
mattri
4 Cylinder Engines
Jul 28, 2006 07:26 AM
