E4OD TECH QUESTION. FREAKY BEHAVIOR!
Old Nov 7, 2017 | 07:42 AM
  #46
BIG ZILLA's Avatar
BIG ZILLA
Talking HAPPY HAPPY HAPPY
New TECA installed and working! I had to make slight alterations to the mounting bracket near the kick plate. The housing to the new unit was slightly different, but came with a large sticker attached what's said "this unit may look different but will function properly"
A REALLY HEART FELT THANKS TO EVERYBODY WHO HELPED THIS GUY WHO KNOWS NOTHING ABOUT AUTO ELECTRIC WALK THROUGH THIS PROBLEM AND SOLVE IT THE RIGHT WAY. YOU GUYS ARE GREAT!
Old Nov 7, 2017 | 07:55 AM
  #47
BIG ZILLA's Avatar
BIG ZILLA
BTW The substitute controller listed in post #11 byF250HDXLT (part # F4TZ-12B565-AA) works well in my '91. I notice an improvement over the old controller... definitely an upgrade!
THANKS AGAIN
Old Nov 7, 2017 | 07:35 PM
  #48
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I am impressed with this thread too. Lots of good work. I'm saving a link.
What did you do about your voltage issue that started this? Have you read about the alternator fire hazard to see if it applies to your truck?
Old Nov 8, 2017 | 01:41 AM
  #49
BIG ZILLA's Avatar
BIG ZILLA
The voltage regulator was the culprit. It was replaced BEFORE addressing the transmission problem. I have not heard of the fire hazard, please explain.
Old Nov 8, 2017 | 04:48 AM
  #50
HardScrabble
https://www.ford-trucks.com/forums/1...idi-guide.html
Here's another one:
https://www.ford-trucks.com/forums/1...ade-issue.html
One more:
https://www.ford-trucks.com/forums/1...lp-please.html
Check this out and see if it applies to your truck. I have a 460 in mine and haven't done the upgrade. I need to look closer at this issue.
If the load on your alternator is through a blade connection instead of a bolt-down connection it can be an issue. If the blade connection gets loose, corroded, high resistance, loaded and hot, it's a problem.
As an example, if I jumpstart someone's car I don't run my truck with the load of the jumpstart. I dont want that load on my old blade connection. Don't want my old alternator loaded like that.
Old Nov 8, 2017 | 05:20 AM
  #51
BIG ZILLA's Avatar
BIG ZILLA
Here's another one:
That is an upgrade that is definitely in my future.
1995F150XLT4x4
20
Jul 15, 2014 02:15 PM
big ole ford
Aug 27, 2012 02:29 PM
DANA SCOTT
Nov 4, 2005 07:00 AM
seanernet
Oct 18, 2003 07:44 PM
eakanator
Jun 4, 2002 09:17 AM
