PSD engine warranty?
Old Nov 3, 2017 | 10:44 PM
Larrymac52's Avatar
Larrymac52
I saw that my dog's vet has a 2016 F-250 PSD. I asked him how he liked it. He said it was a great truck. Only one problem in the first 80,000 miles. He said the turbo stopped working at 70,000 miles, and they just replaced it. No charge. I see the truck has 3/36 and 5/60 like most, but what is the engine warranty?
Old Nov 3, 2017 | 11:48 PM
Robb81's Avatar
Robb81
5yr/100k miles
Old Nov 4, 2017 | 09:51 AM
Dallasbrown's Avatar
Dallasbrown
Powertrain is 5/60,000, PSD is 5/100,000
Old Nov 4, 2017 | 12:17 PM
A&Pmech's Avatar
A&Pmech
Here's your engine warranty:
Your vehicle’s direct injection diesel engine and certain engine
components are covered during the PowerStroke Diesel Engine Coverage
Period, which lasts for five years or 100,000 miles, whichever occurs
first. The following parts are covered during this extended coverage
period: the engine, cylinder block, heads and all internal parts, intake
and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil
pan and pump, water pump, fuel system (excluding fuel lines, fuel tank
and frame mounted fuel conditioning module sometimes referred to as
the frame mounted pump/filter/water separator or frame mounted fuel
filter/water separator), high pressure lines, gaskets and seals, glow plugs,
turbocharger, two-stage turbocharger assembly, turbocharger actuator,
powertrain control module, high pressure fuel injection pump assembly,
injectors, injection pressure sensor, fuel rail pressure sensor, exhaust
back pressure regulator and sensor, exhaust pressure sensor, manifold
pressure sensor, intake air temperature sensor, crankshaft position
sensor, camshaft position sensor, accelerator switch.
Old Nov 4, 2017 | 05:17 PM
Larrymac52's Avatar
Larrymac52
Thank you guys.!
ArtsBest
Sep 19, 2022 12:41 PM
nycsteve
6.4L Power Stroke Diesel
Jun 9, 2022 05:33 PM
edroe
6.7L Power Stroke Diesel
May 23, 2019 09:27 PM
tnhunter69
Jan 8, 2018 01:16 PM
bobsplus
Jan 25, 2016 03:40 PM
