Does'nt emissions equipment have a 100k warranty? I thought I read that somewhere.
This is what is printed in the Warranty Guide:
Your vehicle’s direct injection diesel engine and certain engine components are covered during the 6.0L/6.4L PowerStroke Diesel Engine Coverage Period, which lasts for five years or 100,000 miles, whichever occurs first. The following parts are covered during this extended coverage period: the engine, cylinder block, heads and all internal parts, intake and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil pan and pump, water pump, fuel system (excluding fuel lines, fuel tank and frame mounted fuel conditioning module sometimes referred to as the frame mounted pump/filter/water separator), high pressure lines, gaskets and seals, glow plugs, turbocharger, two-stage turbocharger assembly (6.4L), turbocharger actuator (6.4L), powertrain control module, engine control module (6.4L), high pressure fuel injection pump assembly (6.4L), electronic driver unit, injectors,
injection pressure sensor, fuel rail pressure sensor (6.4L), high pressure oil regulator, exhaust back pressure regulator and sensor, exhaust pressure sensor (6.4L), manifold pressure sensor (6.4L), intake air temperature sensor (6.4L), crankshaft position sensor (6.4L), camshaft
position sensor, accelerator switch.
The exhaust/DPF is listed under the emissions part fo rvehicles with GVW >8500 is 5/50,000 warranty.
I had an injector go bad on my '08 F-250 which ruined the DPF. Warranty covered all expenses, but on the bill I received from the dealer it showed the filter was $1600.00, the labor to install it was not broken out so I do not know that number.
That is the price Ford payed the dealer for as warranty work. Guaranteed you won't buy it for that price.
This is what is in the Diesel Emission Warranty Book:
List of Parts Covered for 5 Years or 100,000 Miles (whichever
occurs first) by Emissions Warranties for Diesel Engines
• Air Flow Sensor
• Air Induction System
• Catalytic Converter (including
Diesel Particulate Filter and
Diesel Oxidation Catalyst)
• Cold Start Enrichment System
• Electronic Engine Control Sensors
and Switches
• Electronic Engine Control Unit
(ECU)
• Emissions Label
• Exhaust Gas Recirculation
(EGR) System
• Exhaust Manifold
• Fuel Injection System
• Fuel Injector Supply Manifold
• Intake Manifold
• Intercooler Assembly - Engine
Charger
• Malfunction Indicator Lamp
(MIL)/On-Board Diagnostic
(OBD) System
• PCV System and Oil Filler Cap
• Supercharger Assembly
• Throttle Body Assembly (MFI)
• Turbocharger Assembly
Important Information About List of Parts
Also covered by the two emissions warranties are all emissions-related
bulbs, hoses, clamps, brackets, tubes, gaskets, seals, belts, connectors,
non-diesel fuel lines, sensors, and wiring harnesses that are used with
components on the list of parts, above.
Concerning parts that should be replaced on a certain maintenance
schedule: these parts remain under warranty until : (a) the first replacement
time that is specified in your Owner Guide and the Scheduled
Maintenance Guide; or (b) the time or mileage limits of the Federal
Defect and Performance Warranties (whichever occurs first). Your Ford
Motor Company dealer maintains a complete list of parts covered by
emissions warranties. For more details about the specific parts covered
by the Emissions Defect Warranty, contact your dealer.
[QUOTE=nycsteve;9419120]Anyone have an idea what Ford charges for this? I heard the part alone is 2K. I dont have an issue, its just a question that came up
I just left my Ford dealership and they said it was going to cost me an estimated 8k. I left because I could not do that right now.
