Weird 203 shift pattern
Old Nov 2, 2017 | 08:02 PM
Supercoltsfan's Avatar
Supercoltsfan
So I'm working on this 203 I have...and I feel like it has a weird shift pattern.
It moves in this pattern:
I knew something was off about it when I bought it....used all the things I found to get a good deal, but now its time to fix them...any thoughts?
Ive identified it as a 203, and if its not it looks just like one (tag is missing)...and the 203 shift pattern is different than my pattern.
Old Nov 3, 2017 | 12:04 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
203 on left 205 on right. Are there any other markings on the case body?
Dana/Spicer Model 20
Identify: Single shifter; same casting as the later Model 18; rear output is centered.
Low-Ranges: 2.0, 2.34, 2.46
Lubricant: 85W-90 gear oil
Notes: Versions also appeared in Jeep, IH, Ford, and Chevy 4x4s. Some parts are interchangeable among versions. The ’66-’72 Bronco had the T-shift with 2.46 low-range; ’73-’77 vehicles had the 2.34-geared J-shift variant. The Bronco Model 20’s sliding gear can be combined with Model 18 gears to create a 2.46 low-range in Jeep and IH Model 20s.
http://www.fourwheeler.com/features/...uide/#photo-02
Maybe you have a Dana Spicer Jeep Dana 20? it had a j shift pattern. http://www.novak-adapt.com/knowledge...cases/model-20
Old Nov 3, 2017 | 12:33 AM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
This is a Ford NP203 shift pattern, as I understand (i.e. there may be other deviations). Easy to tell a 203 (it's huge, two linkage arms on the driver's side, etc.).
Old Nov 3, 2017 | 07:55 AM
77&79F250's Avatar
77&79F250
Wow that is interesting, is that the pattern on your 77 F250 xfer case?
If your truck a early year made 77? Maybe you have a Dana 24?
https://www.ford-trucks.com/forums/9...mpilation.html
"All Highboys had divorced transfer cases, as opposed to married transfer
cases. A married transfer case is bolted directly to the transmission. A
divorced transfer case is bolted onto its own cross-member, and is
separated from the transmission by a driveshaft. Highboys had Dana 24
part-time transfer cases from 1967-1973, and either the standard NP205
part-time or optional NP203 full-time transfer cases from 1973-1977.5.
The NP205 is the strongest and most desirable factory transfer case.
The Dana 24 is a cast-iron, gear-driven, part-time, 2-speed case with
1.86:1 gears. The NP203 is a chain-driven, full-time, 2-speed case with
2.00:1 gears. The NP205 is a cast-iron, gear-driven, part-time, 2-speed
case with 1.96:1 gears."
Old Nov 3, 2017 | 09:29 AM
Idaho Highboy
Veteran: Navy
Rich, yes my truck is an early '77 with a divorced 203 (and a part time 2WD kit) and two linkage arms. The P-PO gave me the shift pattern I posted, which does match the research I've seen; I'd like to see what NP203 pattern you have that shows both the regular 4x4 and "lock out" 4x4 settings. Unfortunately my truck came with a stupid 8-ball for a shift **** and I'm working on my transfer case's linkage (i.e. it's too sloppy to move like it should). Once I get the linkage correct, (November project) I'll confirm the shift pattern I've been given.
- IH
Old Nov 3, 2017 | 11:21 AM
77&79F250's Avatar
77&79F250
To the OP are you SURE it is a NP-203?
IH I am looking for the pattern difference..
62FE4x4
Apr 16, 2012 10:47 AM
1974F100
13
Dec 12, 2010 11:00 PM
TFR
Jan 25, 2005 12:39 PM
nicolds
1966 - 1977 Early Broncos
Aug 16, 2004 08:26 PM
dkgibson
Jun 30, 2004 07:27 PM
