Sponsored by: Real Truck
Engine control relay?
Old Nov 1, 2017 | 08:46 PM
Lordofdagers's Avatar
Lordofdagers
Hi Al I recently took my truck into the shop. They tell me I need a new engine control relay. I can't find it in the manual or anywhere on the internet can someone tell me what is actually called?
Old Nov 1, 2017 | 11:19 PM
Pocketlint's Avatar
Pocketlint
Maybe you could help us out a little with some more details, you posted no information about your truck.
If you give us the year, model, engine etc that would probably help in getting you an answer
Old Nov 2, 2017 | 03:54 AM
seville009's Avatar
seville009
What was the issue they were working on (why did you bring it in for repair)? Would help narrow down what they might be talking about.
Old Nov 2, 2017 | 07:21 AM
Lordofdagers
2001 F250 whith a 7.3. This was a no start issue with no codes
Old Nov 2, 2017 | 07:25 AM
thomabb's Avatar
thomabb
Engine Control Module? Powertrain Control Module?
Old Nov 2, 2017 | 07:46 AM
Pocketlint's Avatar
Pocketlint
ok let me ask you this what did you all have a look at before you took it to that shop? Did you check all your fuses? Clean your battery terminals? check your glow plug harness? Check the EGR valve?
When you crank the truck are you seeing anything on the tachometer? Any white smoke coming out of the tail pipe? Any smoke at all coming out of the tail pipe?
The more details you can give us of what you did before you took it to the shop and what the shop all did and how they arrived at their conclusion will help us with giving you better advice.
Old Nov 2, 2017 | 09:44 AM
Copper.Farm's Avatar
Copper.Farm
For clarity, 7.3l does not have an EGR.
Old Nov 2, 2017 | 10:31 AM
Lordofdagers
It has new batery's, new alternator, just put in a new power steering pump, new icp, they told me I needed a new high pressure oil pump, and ipr they are in and new. They gave me a part code AR272 it is a relay. But the term they used to tell me what it is for makes no sense to me.
Old Nov 2, 2017 | 11:23 AM
Mike1's Avatar
Mike1
The AR272 is a fuel pump relay which would be under your hood I'm guessing on the driver side near the firewall. From what I'm finding on the interweb is that it costs about $5 - $10,
treed36
Dec 10, 2012 09:01 PM
florida_1959
Apr 28, 2012 07:06 AM
Nice Work Truck
Jun 2, 2011 04:12 PM
elmer6400
1983 - 2012 Ranger & B-Series
May 27, 2010 08:31 PM
