Sponsored by: Real Truck
engine swap
Old Nov 1, 2017 | 01:35 PM
corey91's Avatar
corey91
engine swap
I have a 2008 ford f250 with a 6.8 L in it that blew up. I was just wondering if a 2000 6.8 will work in my 08'. I can't find anything on the internet that says either way other than the 2000 is a 2 valve and the 2008 is a three valve. Just wondering if they are interchangeable?
Old Nov 2, 2017 | 06:40 AM
redford's Avatar
redford
FTE Leadership Emeritus
The trick will be creating a management system that will control the 2V engine and the 5R110W transmission.
Old Nov 2, 2017 | 09:04 AM
Copper.Farm's Avatar
Copper.Farm
Simply and direct answer is not without significant challenges, including the instrument cluster
Old Nov 2, 2017 | 10:32 AM
FractureCritical's Avatar
FractureCritical
it will be cheaper, faster, and easier to just get the correct motor instead of trying to hack together a solution to force fit an 18 year old motor. even if the 2000 motor were FREE, you'll get eaten alive by all the the engine and transmission management changes.
check out a salvage aggregation site like car-part.com and find the right motor.
Old Nov 2, 2017 | 12:41 PM
redford's Avatar
redford
2nd issue. 3V engines use electronic throttles. 2V engines use mechanically linked throttles.
Old Nov 2, 2017 | 12:46 PM
finn's Avatar
finn
No, unless you are an experienced fabricator and engine control system guru.
Alternatively you could also do it with an open checkbook and the right specialty shop, but the bill would be about the same as a brand new truck.
Andrew Romo
6.2L V8
Nov 8, 2025 09:25 AM
Dieseltorque
Sep 12, 2012 08:10 AM
77F2
Engine Swaps
May 27, 2012 01:48 PM
zems
Dec 12, 2005 02:36 PM
DT 466Man
Engine Swaps
May 1, 2004 06:45 PM
