2003 expedition heater core problems
Old Oct 30, 2017 | 10:52 PM
78 f150ranger lariat's Avatar
Ok y'all I'm stuck and need all the help I can get. I'm trying to replace my heater core and this is my first one so I pull my dash and everything disconnected the lines to the core got it all to where I can see the core but can't get the box off to pull it out....what am I not doing here?
Old Oct 31, 2017 | 07:00 AM
projectSHO89's Avatar
projectSHO89
The plenum is probably attached to the firewall with studs that go through the firewall and have nuts on the engine side.
Old Oct 31, 2017 | 07:55 AM
I pulled one out from under the hood didn't see another one but I'll go back and check
Old Oct 31, 2017 | 08:16 AM
projectSHO89
I haven't had the pleasure of doing a heater core on your particular vehicle, but I've usually found three studs/nuts that hold the plenum to the firewall.
You did evacuate the AC system and disconnect those lines also?
Old Oct 31, 2017 | 06:41 PM
No not yet and I can't find any others studs to the firewall if I could find a diagram of the box I could probably do it but i can find nothing no where it's been 3 days now and I'm staying to get aggravated
Old Oct 31, 2017 | 07:58 PM
projectSHO89
See attachments.
Well, pulled up the factory procedure. It keeps getting more and more complicated. Check out the instructions for the rear footwell duct.
Maybe someone who has done this before on your particular truck can offer some advice, all I can do is refer to the service manual.
Try asking in the Expy forum, more likely to hit an owner that's BTDT.
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 5, 2017 | 02:17 PM
MIRONWORKER's Avatar
MIRONWORKER
HEATER
HELLO,NOT SURE IF IM RIGHT PAGE,I HAVE 2001 F-150,HAD WORK DONE,NOW MY HEATER ONLY BLOWS ON HIGH,AND WHEN IT DOES,NOT ALWAYS BUT SEEMS TO SMELL LIKE ANTIFREEZE,PROBOBLY 2 DIFFERANT ISSUSES. HEATER CORE ? AND WHY ONLY ON HIGH PLEASE HELP,NOT TO COMPUTERISH?
5.4AZ4X4
1997 - 2003 F150
40
Jun 6, 2022 01:01 PM
CB3
Oct 1, 2013 09:48 AM
samckernan
Mar 7, 2004 10:23 AM
