E4OD-Headaches
Old Oct 30, 2017 | 10:13 PM
Frazier88's Avatar
Frazier88
E4OD-Headaches
I just put a new/rebuilt tranny in my 94 f-250. The tranny went into limp-mode on test drive as soon as the truck got up to temp. With the key on I'm getting a buzzing noise from the solenoid pack in the tranny. The only tranny code i get with KOEO is for the TOT sensor which I'm assuming was from the heat build up during the test drive after it went into limp-mode and code 55 which is low voltage to PCM pin #5. I did not have any shifting problems with the old tranny.
Old Oct 31, 2017 | 06:37 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
If the old one shifted good why did you replace it?
Go ahead and post up all of your codes. Did the tests run to completion?
I have never heard any electrical noise from my transmission.
Call the transmission builder. Who built it?
Old Oct 31, 2017 | 05:47 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Replace your PCM relay (for IDI diesel trucks,TECA relay). When the solenoids "buzz" the relay is bad.
ford superman
Apr 18, 2017 09:24 PM
SideWinder4.9l
Jul 25, 2013 08:22 PM
nomad221
May 10, 2012 03:24 PM
Fully_Loaded
Sep 8, 2009 01:44 PM
broncobasher
Jan 8, 2009 04:17 PM
