Very weird electrical problem with tail lights. HELP
Old Oct 29, 2017 | 06:26 PM
TwoStroke91's Avatar
TwoStroke91
Unhappy Very weird electrical problem with tail lights. HELP
Hi all , greetings from London, UK .
I've got my 55' f100 with 292 y block from North Carolina earlier this year. It has been converted to 12V and has the original wiring all around.
Overall very good truck , i've done just little things on it to make it better.
However , yesterday the brake lights and blinkers stopped working all of the sudden. Just the running tail lights were working.
I changed the old wiring with new connectors and wires and all started working again apart from the driver side brake light ( blinker and running light was fine). Then I changed the ground wire and hurrah, all worked.
They all worked but i never started the truck , all the tests i did were done with the truck off , just the ignition on and light switch on.
When i started the truck , NOTHING . Only the passenger blinker worked , thats it.
Any ideas what might be the issue ? Btw I just found out that the battery is grounded to the chassis instead of the engine.
Old Oct 29, 2017 | 06:30 PM
CharlieLed's Avatar
CharlieLed
No such thing as "grounded to the chassis INSTEAD of the engine"...go back and install bonding straps to the chassis, body, and engine. All three need to be grounded together. You cannot install TOO many bonding straps!
Old Oct 29, 2017 | 06:37 PM
TwoStroke91
Ok , will do. Will give feedback if problem solved
Old Oct 29, 2017 | 07:36 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
For the majority of times, most any electrical problem can be traced back to a faulty ground circuit.
When you add the additional ground straps take a few minutes to scratch/grind/etc the paint off in the area where the strap goes. You want good metal to metal contact. It's also a good idea to use those star type lock washers as they "bite" into the metal pretty good
Good luck, I hope you get the lights working so that you can go drive it around and enjoy it.
Bobby
lakeboater
May 14, 2018 06:36 AM
mrgene20
Jun 10, 2013 12:41 AM
HeavytruckFan
Sep 11, 2012 07:16 PM
TheMech
Jan 30, 2008 10:15 AM
earthworms
Dec 6, 2001 09:44 PM
