P0405 egr code
Old Oct 29, 2017 | 01:40 PM
cookingguy's Avatar
cookingguy
P0405 egr code
So my truck has been acting strange the last few weeks. At idle it's can be a bit rough. Also when driving at around 50mph at around 1200 rpm it is a little bit jerky not really bad just a little bit. So today I got the p0405 code . I am pretty sure that I replaced the egr valve less then a year ago. Any thoughts guys
Old Oct 29, 2017 | 02:46 PM
olfordsnstone's Avatar
olfordsnstone
Try disconnecting the plug at the EGR and see if there is a difference in how it runs.
Old Oct 29, 2017 | 04:10 PM
cookingguy's Avatar
cookingguy
I will try that tomorrow morning
Old Oct 29, 2017 | 08:57 PM
olfordsnstone
My understanding is that the valve will default in the closed position when the engine is shut down (off), which is where you want it when you pull the connector from the valve. My thinking is that if she runs normal again after disconnect, that should help to further ascertain the culprit being the EGR valve itself. But maybe some of the more savvy diesel heads here might chime in and add to this.
Old Feb 25, 2025 | 10:54 PM
karljay's Avatar
karljay
SOLVED. The MAP sensor on the firewall was disconnected from the back of the TB gooseneck thing. It's a worn and loose fitting and it came off.
ben158
Nov 20, 2014 11:58 AM
propellerhead
1983 - 2012 Ranger & B-Series
Jun 14, 2013 08:14 PM
Misky6.0
Jun 6, 2011 11:15 AM
MikeB 88
Aug 4, 2010 06:13 PM
allenw
Modular V8 (4.6L, 5.4L)
Aug 7, 2004 10:44 PM
