1978 - 1996 Big Bronco
weak driver side window
Old Sep 10, 2003 | 06:13 PM
broncobillybob's Avatar
broncobillybob
Unhappy weak driver side window
hi all, i'll get right to it. if my driver side glass gets too low you have to help it back up. or pull it out of the door w/ pliers when it gets all the way down into the door. i know its not the switch bc it works when halfway up, weak motor? help!?! oh yeah its a 1993 xlt)
Old Sep 10, 2003 | 08:45 PM
Roscoe1818's Avatar
Roscoe1818
Weak motor or regulator would be my thingking. Havent done much work on them though, so that's all I got. Good luck.
Old Sep 11, 2003 | 09:04 AM
BillyBob69's Avatar
BillyBob69
BILLYBOB????? IS THAT YOU CUZ?????
You rwindow sounds like mine was about 2 onths ago....you can get another window motor for it at an aftermarket web site fairly cheap....I had to replace the other side once I saw how fast the drivers side worked. the change out isnt too bad. can do both in 1 day easily.
Old Sep 11, 2003 | 09:06 AM
BillyBob69's Avatar
BillyBob69
Whoops..sorry I got mine thru JCWhitney.
Old Sep 11, 2003 | 03:43 PM
broncobillybob
thanks guys. billybob were probably related somewhere on the tree. how much did jcwhitney cost you? a dealer told me $136 just for the motor and not including labor and all that. also the for the passenger the that window works, but the driver has to lean over to work it. thats not fun. any tips?
Old Sep 11, 2003 | 03:46 PM
89broncobob's Avatar
89broncobob
Go and get it from a junk yard.i pulled my from a town car and it fit fine ...dont go to a dealer ..good luck ..20 bucks from a junk yard here in fl.
Old Sep 11, 2003 | 03:48 PM
broncobillybob
sweet didnt think about that. my friends dad owns a junkyard. just get it remotely same year right?
BillyBob69's Avatar
BillyBob69
The price actually is right along what I paid for the parts..but I installed myself. As for the passenger window working only from that door, I would check the outputs on your drivers door switch when you try to operate the passenger window.
Old Sep 11, 2003 | 03:51 PM
broncobillybob
ok i'll do that. some other threads said to remove light **** on dash. u had release tension on the spring? they were a little unclear on where that is located. anybody got anything? -william
Old Sep 11, 2003 | 03:53 PM
89broncobob
arount the same year is right ..and you will see on the metal of the door there is dimple's ..just drill out holes big enough to get your socket in there ,thats the best way to do it ,rather then trying to reach around the inside of the door .if you drill access holes should onley tack you about a hour our so..good luck ,glad to help..
Old Sep 11, 2003 | 03:54 PM
89broncobob
boy my spelling suxs...lol
Old Sep 11, 2003 | 03:56 PM
broncobillybob
thanks 89broncobob
Old Sep 11, 2003 | 03:57 PM
89broncobob
any time ..what year is yours..you should put it on the bottom of your post it will help us help you ...lol
Old Sep 11, 2003 | 04:02 PM
broncobillybob
i have a 1993 xlt. w/ 351 5.8L (is it safe to assume its a windsor?)
about 2 weeks ago i had a flowmaster put on w/ 3.5 inch tips. after that i put on a kandn filter. plan to put on headers and 2003 f250 rims (the star pattern) but i dont think they will fit. i like the foxbody too, had one before my truck. it was a four banger though. -william
TravisG
Aug 23, 2013 01:22 AM
Jackedup00
1997 - 2003 F150
Apr 8, 2013 10:33 AM
EMD_DRIVER
Apr 24, 2011 10:04 PM
DanCampbell
17
Nov 6, 2010 11:43 AM
2 stroke man
23
Feb 15, 2008 10:48 AM
