87 302 probs...help
Old Jan 19, 2008 | 10:21 PM
2 stroke man's Avatar
2 stroke man
87 302 probs...help
hey guys new to this forum. i'm usually over there modding powerstrokes lol. my dads 1987 f-150 has always had a few bugs. it was always a lil weak, but had a fuel problem on rear tank. it would cough and sputter and die on it, when it tried to work at all. sometimes it didnt work. now, he got that fixed after several years of tinkering around. it is now weak. i mean weaker than cat ****. as in cant get out of its own way, and has now cracked 2 drivers side exhaust manifolds. any ideas why? maybe running lean on that side? could it have dead injectors on that side causing it to run lean and be weak and crack manifolds? is it a common prob?
Old Jan 20, 2008 | 09:09 AM
jr32560's Avatar
jr32560
I would look towards a clogged cat!!
Old Jan 20, 2008 | 09:26 AM
flareside_thunder's Avatar
flareside_thunder
I second that......also, how long has it been since a FF change?
JR
Old Jan 20, 2008 | 12:22 PM
2 stroke man
not long i dont think. but its a dog.
Old Jan 20, 2008 | 03:36 PM
2 stroke man
it dont appear to have a cat on it. and it has cracked the manifold twice on the same side.
Old Jan 20, 2008 | 04:33 PM
redneckgrl88's Avatar
redneckgrl88
my 87 has 2 cat's. are you sure?
Old Jan 20, 2008 | 04:42 PM
jr32560's Avatar
jr32560
my 88 has 2 also??? unless his has been removed???
Old Jan 20, 2008 | 04:47 PM
kcb37's Avatar
kcb37
Make sure the exhaust is secure. If it bounces a lot it could crack it. I have heard of that problem with 302/351's. I don't know how true it is though.
Old Jan 20, 2008 | 05:39 PM
cowchasinsix's Avatar
cowchasinsix
Both sides of my '91 are cracked (302). I would agree with previous poster to check to be sure that the exhaust isn't flopping around. From what I understand cracking these manifolds isn't uncommon.
Old Jan 20, 2008 | 05:59 PM
flareside_thunder
Hmmmmm, check the timing too may be too far advanced or retarded......play it by ear first then if you must use a timing light, how long since the O2 sensor been changed?could be causing it to run WAY too rich or even too lean....Luck
JR
Old Jan 20, 2008 | 06:28 PM
jr32560's Avatar
jr32560
in response to cracked manifolds-the exhaust pipes should crack before the cast iron manifolds!!! am I the only one who knows this!!!
Old Jan 20, 2008 | 06:43 PM
flareside_thunder
Really?How is that?Because every truck I have ever seen has cracked manifolds......and the pipes are hanging from rubber bushings.....explain
JR
Old Jan 20, 2008 | 06:47 PM
jr32560's Avatar
jr32560
they reply was exhaust flopping around??? meaning broken hangers!!pipes will break or crack before manifolds?? don't you think???
Old Jan 20, 2008 | 06:49 PM
jr32560's Avatar
jr32560
see kcb37 and cowchasinsix reponses!!
Old Jan 20, 2008 | 07:04 PM
2 stroke man
the pipes come down from each side (exhaust is secure) and into a y-pipe that goes into muffler, then out the back. like i say, very weak too. like cant get out of its own way. has me confused.
