Need help with miss
Old Sep 10, 2003 | 03:25 PM
meck1's Avatar
meck1
Need help with miss
Mine is an '87 with 145,000 on it. Engine basics (compression, oil pressure, etc.) are fine. All sensors and idle air bypass have been replaced in the last year. Plugs, wires, ignition module are new. It runs great once its warmed up, but when cold it acts/feels/sounds like its only firing on five cylinders.
Can anybody give me some advice as to how to figure out what is going on? I'll appreciate any help--
Thanks
Old Sep 11, 2003 | 04:32 PM
javi2001's Avatar
javi2001
Need help with miss
While engine is cold, start it and using an insulating tool disconnect 1 spark plug wire then observe if engine get worse or continue same. Reconnect and test next cylinder, do same for all.
If engine get worse, this cylinder is working. If engine gets worse this is the problematic cylinder. Double check for spark plug, wire, distributor cap.
If everythink is OK, then make a compresion test with engine cold and then with engine hot, compare readings.
Regards;
Gsmitty53
May 10, 2014 02:38 PM
broncoIIfreak
Bronco II
Oct 5, 2010 02:41 PM
Henry Carter
Aug 8, 2010 09:33 AM
David20Dsa20
17
Mar 1, 2008 01:09 PM
