HELP! I cant seem to decode my VIN on my 77 F-150. Its 11 digits and i cant find a decoder that helps, or actually works. The VIN is F14HLX85764 please help
Ok. What were stock axles on this truck? I bought the truck and found a 300 I6 in the engine bay. Don't know why. And my top speed is only 60 with the motor about pegged out. Would it have come from the factory with 5.13 gears?
You can't get any axle info from the VIN.
Look on the driver's door for the warranty plate, that's the small metal plate that's riveted to the door just below the latch. First line is the VIN, the last code on the second line is the "AXLE" code. Post that and we can tell you what the truck came with originally, but from the sound of it things have been changed.
And no, you couldn't get 5.13's from the factory.
