Need A Bellhousing.. HELP
Old Feb 28, 2008 | 02:36 PM
David20Dsa20's Avatar
David20Dsa20
Recently, the bellhousing blew apart on my 86 F350 . Need a new one and its almost impossible to find. Has the t19 transmission, bolts up to a 460, hydraulic clutch. 4 speed manual. HELP HELP HELP
Old Feb 28, 2008 | 03:04 PM
irishammer's Avatar
irishammer
David try posting in the correct forum. This is for 2009 F150 only...hopefully an admin will move it there for you. They will be able to help you better!!
Old Feb 28, 2008 | 07:07 PM
David20Dsa20
sorry i am new to this stuff
Old Feb 28, 2008 | 07:47 PM
uncle.stosh's Avatar
uncle.stosh
It is?
I thought it was for 1980 - 1986 F100, F150 And Larger F-Series Trucks, just like the forum title says....
Old Feb 28, 2008 | 07:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Blew it up??
I broke the slave cylinder boss off the side of mine.
Lucked out and had a local auto wreckers deliver it to my buddies shop.
$60 IIRC, that was 5 years ago.
Help you with what?
What happened?
Old Feb 28, 2008 | 08:00 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by uncle.stosh
It is?
The post did get moved, I didn't see it until now.
Old Feb 28, 2008 | 08:04 PM
Franklin2's Avatar
Franklin2
You right, there are none in Wisconsin. But I did a nationwide search and found these.
1984
Transmission Bellhousing Only
Ford Truck F350 not Super Duty 460 #29795 $200 Bevill's Salvage USA-OK(Ravia) Request_Quote 1-800-239-2739 Request_Insurance_Quote
1986
Ford Truck F350 F-4 AB8035 $151 A and B Auto Salvage USA-GA(Griffin) E-mail 1-800-726-1570
1984
Ford Truck 250 SHIFT FORK ONLY,NEW,OEM HILL $30 Klamath Auto Wreckers USA-OR(Klamath-Falls) E-mail 1-800-452-3301
1984
Ford Truck 250 M1780 $Call Barger-Mattson Auto, Inc. USA-ID(Twin-Falls) E-mail 1-208-733-3743
Old Feb 29, 2008 | 10:53 AM
David20Dsa20
yes it was the slave cylinder boss part of it. And I am new and posted in the wrong forum but was moved here. I tried the places listed above and still no luck. Need help finding a new bellhousing
Old Feb 29, 2008 | 11:20 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well it does seem Y2K, one of this sites sponsor's, has a E4TZ7505B for $248.89
See this old thread: w/ pn and I checked their site for the new price.
I know "search" sux but sometimes it works.
https://www.ford-trucks.com/forums/4...f-250-4x4.html
Old Feb 29, 2008 | 01:19 PM
David20Dsa20
from what ive heard the 2wd bellhousing would also work. ive been searching everywhere for the past 3 days and still no luck
Old Feb 29, 2008 | 02:11 PM
Franklin2's Avatar
Franklin2
Can the piece be welded? Aluminum welds and holds good if you get someone who knows what they are doing.
Old Feb 29, 2008 | 02:58 PM
David20Dsa20
Thats what i meant about blowing up. There were about 10 small pieces on the ground and it would have to be put together like a puzzle little own the pieces we didnt find. Trust me i already thought of it.
Old Feb 29, 2008 | 04:33 PM
Franklin2's Avatar
Franklin2
If it's this hard to find a bellhousing, then just go ahead and get a zf 5 speed for it. That tranny has the bellhousing made onto it, and has the hydraulic clutch setup too.
One problem though. This tranny may be longer than the one you have, so you might have to modify or get new driveshafts. With gas prices so high, it may pay for itself in a couple of years since it has overdrive.
Old Feb 29, 2008 | 05:43 PM
big hoss 29's Avatar
big hoss 29
Well, the only problem with that thought Franklin is that a bellhousing can be had for around $200 give or take and a ZF tranny can be around $1000 in a yard. that's not really an economical deal.
Old Feb 29, 2008 | 06:04 PM
uncle.stosh
I know someone with complete 460 driveline already out of the truck. Let me check with him and see if he'll part with the bellhousing.
