MPG Indicator vs Math
Old Oct 23, 2017 | 10:38 PM
ScrmnWoody's Avatar
ScrmnWoody
I've been watching the miles per gallon indicator on the display and it doesn't seem to match the math when I fill up at the pump. I'm only on my third fill up, but the math always comes out about a half a mile per gallon less than what the indicator on the display reads.
Thoughts?
Old Oct 23, 2017 | 11:05 PM
Sleepyguy's Avatar
Sleepyguy
The fuel consumption of the engine is not linear and depends on may factors. I would not hold any of it as the truth above all else.
Driving conditions style wait times. I also recall they changed the system as it was over estimating mileage and causing issues.
I do believe there is posts on here about the massive fuel mileage debate.
Old Oct 23, 2017 | 11:33 PM
Robb81's Avatar
Robb81
My truck claims about 17mpg for the first 4,000 miles. Calculated actual is about 16mpg.
Old Oct 23, 2017 | 11:47 PM
eberlestock's Avatar
eberlestock
Ford tries to make you think you are getting better mileage than you are!
Old Oct 24, 2017 | 03:22 AM
Omega Man's Avatar
Omega Man
Mine has never been off by more than a 1/10th of a MPG, guess I got lucky.
Old Oct 24, 2017 | 04:47 AM
LiquidSteam's Avatar
LiquidSteam
Thoughts?
If you are using larger diameter wheels its going to make your MPG indicator read low. Exactly how low would be based on your wheel size.
Old Oct 24, 2017 | 05:32 AM
Redrockerstl55's Avatar
Redrockerstl55
I have found the computer on these Super Duty's is pretty accurate compared to other cars from Japan or Germany I have owned. Those VAG and Nissan manufactured vehicles could be off as much as 2.5 MPG. With VAG cars you had to make adjustments using VCDS but you could never really dial it in perfectly.
Nothing beats the manual calculation at the pump. Use the same method each time. I let the pump turn off automatically and then give it one more squeeze until it kicks off. Then I stop and record all my data. Use a system like that every time and you will create a consistent system to get accurate MPG over time.
If the computer on the vehicle is getting within 1 MPG then that is a pretty accurate trip computer.
Old Oct 24, 2017 | 08:58 AM
Tact's Avatar
Tact
This is a little off topic, but I have noticed a big difference in filling up the tank on my new F250 compared to my 2003. When I filled up the 2003 and let the gas handle cut itself off, diesel would spew over the filler neck and flow all over the outside paint. I had to get used to listen as I filled up at the pump; and when you could hear it getting close to being full, I had to baby the pump so that it would not over flow. There was a mod you could do to the tanks to help prevent that, but I never got around to doing it.
With my new truck, I let the pump cut itself off and no spewage. I'll try the method by Redrocker to get a more accurate measure each time.
Old Oct 24, 2017 | 01:01 PM
tjkadar's Avatar
tjkadar
Either method is within the statistical margin of error, but the computer is far, far more consistent than a hand calculation. If you're going to be comparing fuel mileage from one fill-up to the next, use the computer's numbers. Hand calculating has too many variables, including the density of the fuel based on temperature when pumping, whether or not you are on slight incline, decline, or level, and how accurate the station's pump are.
Old Oct 24, 2017 | 01:26 PM
Texmudder's Avatar
Texmudder
You are talking about the "harpooning" mod back from the original 6.0s. From what I read this is no longer needed.
Old Oct 24, 2017 | 01:58 PM
Tact's Avatar
Tact
Yep, same for my previous 7.3.
Old Oct 24, 2017 | 02:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The trip computer calculates mileage over the last 1,000 miles unless you reset it. Are you resetting it each time you fill the tank?
Old Oct 24, 2017 | 03:07 PM
got2haveit's Avatar
got2haveit
1.0 mpg off first fill up, 1.0 mpg off 2nd fill up, .9 mpg off 3rd fill up, .6 mpg off 4th fill up so far for me. I try to do the same procedure each time, fill up til it clicks off, wait 15 seconds, top off. Level ground, no reason for more error really.
Old Oct 24, 2017 | 03:37 PM
tibadoe's Avatar
tibadoe
Each one of my vehicles have been within 1 mpg or less per fill-up. When I fill up the truck this weekend I will most likely see the same thing. I prefer manual calculating over the computer.
Old Oct 24, 2017 | 04:06 PM
rangermc's Avatar
rangermc
Mark,
Is the reset for trip 1 or trip 2. It seems the MPG average is the same after fill up. If it is an average, over what time, or miles or which trip computer? Thanks
Crosby as rangermc
