late 80's meyer plow
Old Oct 22, 2017 | 05:43 PM
wharthog's Avatar
wharthog
Is there anybody out there with a meyer plow on there late 80's bronco, or f series? I need a measurement of the length of the clevis frame, part number 4 on the meyer parts sheet. It is the piece of angle iron that has the brackets welded to it that accept the plow a frame and get the pins installed to hold the plow frame.
I purchased an old conventional used one from a guy that had one removed from a bronco I was told, but the piece i got is too short to connect the vertical pieces dropping from the frame. I'm going to guess it has to be about 31 1/4" long where the one I have is close to 28" long. I want to make one up but I want to make it the correct length.
Old Oct 23, 2017 | 02:59 PM
tjc transport's Avatar
tjc transport
i ain't rite
best way to get the proper measurement is to mount the drop brackets and measure between them.
i just measured the one for my 88 and it is 30 3/4 between drop brackets.
Old Oct 23, 2017 | 04:01 PM
wharthog's Avatar
wharthog
That sounds like a good distance, it would be about what is there now. I have the side plates hanging now. I wanted to see if anybody had the set up and could measure it. I don't have the history of this truck I'm putting the plow on, just thinking I would like to make sure that I have the size correct incase the truck had some minor frame tweaking.
Old Oct 23, 2017 | 06:05 PM
tjc transport
i ain't rite
well, if the frame was tweaked the proper mount wouldn't fit anyway.
bolt the drop brackets tight and measure the distance between them. i bet you will see about the same 30 3/4 inch.
i think that 28 inch lower is for a 77 and older truck with the narrow frame.
wharthog
1978 - 1996 Big Bronco
Oct 25, 2017 04:42 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
Dec 31, 2010 08:18 PM
matt12
Oct 24, 2007 10:39 PM
buffalobob
Mar 1, 2007 03:56 PM
robtinalimon
Dec 28, 2004 05:29 AM
