Trans Fluid Overfill?
Old Oct 22, 2017 | 03:18 PM
Sullid01's Avatar
Sullid01
Hi Guys,
This weekend I swapped my trans pan for an AFE that fits the newer trans filter. I also replaced the toilet paper filter and blew out that line with air. I collected about 9 quarts of fluid and lost some to mess in rags and on myself.
The AFE pan has an additional capacity of 7.5 qt over stock. I added 18 qts figuring the AFE pan is supposed to hold 17 qt total and I probably blew out another 1 qt from the lines to the toilet paper filter. It was a bit hard to estimate the mess - I think it was about a quart - filled two big rags and made two large spots on the driveway. Cold readings on the dipstick suggest way too much fluid.
Mark K says only a warm reading means anything so I am not sure - guess I have to take it for a drive and see what happens and what the reading is afterwards, but I figure I can't be off by much.
Any thoughts - I really would like to avoid a trans fluid explosion under the hood
Old Oct 22, 2017 | 03:32 PM
87crewdually's Avatar
87crewdually
I don't know if you got the instructions or not but here they are.
I wouldn't count on doing the math to calculate a fill. If I were you I'd run it like they say (foot on brake and cycle through the gears and back to park). Then check level. If too high, either suck or drain some out to get it to the correct level.
Old Oct 22, 2017 | 06:42 PM
69cj's Avatar
69cj
Don’t over think this. Drive it. If it’s over filled take some out.No math involved here.
Old Oct 22, 2017 | 08:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That cold reading narrows it down. You're somewhere between 5 quarts underfilled and 5 quarts overfilled. That's how useless the cold reading is.
Old Oct 22, 2017 | 08:54 PM
Sullid01's Avatar
Sullid01
Seems everyone hates math Well I'm going to drive it tomorrow and we'll see what happens. I think I should be within 1 qt plus or minus (you know based on the math thing). Anyway appreciate the words of encouragement.
As a note to anyone installing one of these aftermarket pans, a ball head 6mm allen will save you a lot of time under the cross member. I've got a boat load of tools, but apparently my ball headed allens are all standard, not metric
Old Oct 23, 2017 | 03:57 AM
Yahiko's Avatar
Yahiko
Don't you just hate that when you have all these tools but the one that would make the job go zip.
So post a photo of that pretty pan. I happen to like dark colors.
SoCalAngler
Jul 1, 2018 08:41 AM
SixGunCaliforniaKid
Dec 3, 2013 11:07 AM
marthur9789
20
Jan 9, 2011 04:38 PM
pcf_mark
22
Jan 20, 2010 03:39 PM
desertstorm-007
Aerostar
Sep 22, 2003 01:55 AM
