I've have seen that video before but I did not locate the button he is showing in the video , I have looked under the drivers side by the brake pedal with no luck so is there somthing that needs to be done with the ipc module to have it shown in the message center
Yes I saw that in my manual but I don't have remote start listed in the message center as I would like it to be there that's why I am thinking it has to be something with the IPC module
I changed the following and it ending up working for me
Remote Start: In the BCM module 726-19-01 change 0047 ( disable) to 0148 (enable)
Remote start in cluster: In the IPC module 720-01-02, change 4C0A (disable) to 4F2A (enable)
Ya got it it working, good work! Some minor tweaks and your up and running, always nice if the info would be a little clearer, but sometimes I think the folks that write this stuff up, dont realize most owners are trying to do some of the features and not a tech at a dealer, as it is almost written to a tech's perspective.
