Restoring 1985 f150
If you are using the F250 brakes, use the F250 master and booster.
I'm not so sure that a frame swap would qualify as a restoration, but it's just words and opinions. What will matter is what you vehicle is registered as. The F150 VIN on the cab will legally limit you to F150 weights despite the F250 frame and axles.
If you have any question while doing this, go to a site like Autozone, Advance, O-reilly's, etc. and punch in the f150 and write the part number down, and then punch in the f250 you are using and see if the part number matches. They want to keep the least amount of inventory in stock, so if the part is the same, they will carry only the one part number for both trucks.
farmallmta
11-04-2018 06:29 PM
dyoungen
05-03-2010 10:40 PM
jsganze
02-07-2005 10:51 PM
