Restoring 1985 f150
Old 10-20-2017, 03:49 PM
skinny72's Avatar
skinny72
skinny72 is offline
Restoring 1985 f150
Hi, my boys and I are restoring and f150 we got a 1983 f250 frame in mint condition question is do we need to put a master cylinder and power booster for an f250?
Old 10-20-2017, 04:15 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,751 Likes on 1,419 Posts
What are your plans? You are "restoring" a f150 with a f250 frame? Are they 4x4? The master cylinders are different between a f150 and a f250. It all depends on what suspension and brakes you will be using.
Old 10-20-2017, 05:46 PM
skinny72's Avatar
skinny72
skinny72 is offline
It is a rolling chassis the f250 we are using it all the axles and leaf springs so just wanted to get advice on what needs to be changed over from the 150 to the 250
Old 10-20-2017, 07:30 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
If you are using the F250 brakes, use the F250 master and booster.
I'm not so sure that a frame swap would qualify as a restoration, but it's just words and opinions. What will matter is what you vehicle is registered as. The F150 VIN on the cab will legally limit you to F150 weights despite the F250 frame and axles.
Old 10-20-2017, 07:42 PM
skinny72's Avatar
skinny72
skinny72 is offline
We got a new cab and bed its a frame up restoration on the truck I was just wondering about the brake booster and master cylinder should be one for the 250 since we are using an f250 rolling chassis the axles and suspension to
Old 10-21-2017, 03:03 PM
Franklin2's Avatar
Franklin2
Yes, use the f250 master cylinder. You can look the booster up, it might be the same.
If you have any question while doing this, go to a site like Autozone, Advance, O-reilly's, etc. and punch in the f150 and write the part number down, and then punch in the f250 you are using and see if the part number matches. They want to keep the least amount of inventory in stock, so if the part is the same, they will carry only the one part number for both trucks.
farmallmta
11-04-2018 06:29 PM
dyoungen
05-03-2010 10:40 PM
sphinx
02-15-2008 10:32 PM
jsganze
02-07-2005 10:51 PM
Supercab
04-21-2001 11:47 PM
Quick Reply: Restoring 1985 f150
