F250 & F150 Frames
Old Mar 8, 2001 | 04:05 PM
Supercab's Avatar
Supercab
F250 & F150 Frames
I'm looking at buying a '78-'79 F250,(regular cab) and thinking of swapping all the F250 suspension to my '78 F150 Supercab, question is the 150 frame the same as the 250 or is the 250 somehow thicker or stronger, (both 2wd) Thanks! Rick
Old Mar 8, 2001 | 05:45 PM
deleontow's Avatar
deleontow
F250 & F150 Frames
Same Frame,
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Mar 12, 2001 | 09:17 AM
DannyP's Avatar
DannyP
F250 & F150 Frames
I am not sure about the late 70's models, but the in the late 80's I know that the F-250 frames are about .250" (1/4) thick and the F-150's are about .187" (3/16).
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Apr 21, 2001 | 06:23 PM
monckywrench's Avatar
monckywrench
F250 & F150 Frames
[font size="1" color="#FF0000"]LAST EDITED ON 21-Apr-01 AT 07:35 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 21-Apr-01 AT 07:31 PM (EST)[/font]
Just walked out and checked my '76 F250, and it's slightly thicker than my '77 F100, and is the same as '67-'72 F250 frames. Used a Vise-Grip to check so I can't give the exact gage. Expect the original rubber mounts to be trashed, and get a urethane kit. The cab mounting ears will swap if you have any that rusted out. Just grind or drill the rivets, replacing with fine thread Grade 8 bolts and locknuts. Check rear spring length,(IIRC there are two different lengths) as you may have to move rear spring perches too.
Old Apr 21, 2001 | 10:33 PM
fatforty's Avatar
fatforty
F250 & F150 Frames
Hi, check the spring width too I know on the 80s trucks the 3/4 ton spring is wider than the 1/2 ton so the spring perches will have to be changed from the 3/4 to your 1/2 John
Old Apr 21, 2001 | 11:47 PM
MSTRAWN's Avatar
MSTRAWN
F250 & F150 Frames
doc_f250
Dec 7, 2013 10:30 AM
4xFordFreak
19
Jan 2, 2013 09:59 PM
helipirate
Sep 30, 2012 12:12 AM
scottie2hottie
Jan 2, 2007 11:01 PM
