Curious
Old Oct 19, 2017 | 08:31 PM
Fordv8'460's Avatar
Fordv8'460
Curious
I'm putting a 460 and c6 trans out of a 75 lincoln continental in a 73 1 ton dually. Can anyone tell me how well that combination will jive together?
Old Oct 19, 2017 | 08:59 PM
mark a.'s Avatar
mark a.
You mean is it a easy bolt in or how well should it perform ?
Old Oct 19, 2017 | 09:09 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
2wd regular cab, with the right tire size and gearing in the rearend, if should jive just fine.
If it does not jive enough for you, be ready to fix the gearing or put a aftermarket alum intake and 4 bbl on it. Still not enough... cam and better flowing heads...then headers. Shift kit in the trans.
Then down the rabbit hole you go.$$
Old Oct 19, 2017 | 09:42 PM
four-sixty-power's Avatar
four-sixty-power
the lincoln continental would have had "highway gears" in the rearend, with small tires.
the 73 1 ton dually will have "lower" gears in it by fact of being a 1 ton dually, and bigger tires than the lincoln.
swapping from car to truck with engine "as is" should perform the same or better in the truck as compared to when it was in the car.
If engine has not had a tune-up in a while then fresh oil/spark plugs & wires and throw a timing light on it etc etc and you will have a happy swap. lincoln most likely had a 4bbl carb on there to start with but carb may need a rebuild, AND if you are going to tune it up anyway for performance, then the easiest time to put add performance exhaust headers on it is while the engine is out of the vehicle as its easier to deal with any potential exhaust manifold bolts snapping off in the head.
Old Oct 19, 2017 | 10:10 PM
77&79F250's Avatar
77&79F250
And...460 car exhaust manifolds (especially the passenger side) will NOT work. They are shorter on length and will not clear the frame. So get your self some headers or 460 truck exhaust manifolds.
Old Oct 21, 2017 | 07:42 PM
Fordv8'460's Avatar
Fordv8'460
I haven't checked the plate on the rear end yet but according to the tag inside the door it has 3.00 gears. Might not be original cab. I have a 4 speed also that came with the truck but have heard great things about the c6.
Old Oct 21, 2017 | 08:02 PM
Fordv8'460's Avatar
Fordv8'460
No tag on the rear end but c38458 is stamped into it.
Old Oct 21, 2017 | 08:07 PM
FuzzFace2's Avatar
FuzzFace2
Only thing I can think of looking out for would be maybe the oil pan sump, front/rear, and the oil filter hitting the frame.
Someone pointed out the car exh manifolds.
Last thing would be the frame motor mounts might be different if the truck did not have a 460 to start with.
I had a 76 E350 with a 460/C6 used it to pull a 35 foot 2 car trailer.
Dave ----
Old Oct 21, 2017 | 09:26 PM
Fordv8'460's Avatar
Fordv8'460
It had a 460 in it. Actually heard the old one run in another truck. Would the oil pan be different between car and truck applications?
Old Oct 21, 2017 | 10:11 PM
77&79F250's Avatar
77&79F250
Car motor has a front sump oil pan, 2wd truck motor front sump oil pan. A rear sump oil pan is a better deal for a 4wd application.
A front sump oil pan will work in a 4wd F250, but if you are running stock/worn out
front suspension you CAN hit the front axle pumpkin on the oil pan.
Old Oct 22, 2017 | 10:22 AM
beartracks's Avatar
beartracks
I heard somewhere the Lincoln has different motor mount bosses. Don't remember the particulars.
Old Oct 22, 2017 | 05:59 PM
Fordv8'460's Avatar
Fordv8'460
2wd f350 is what I'm putting the motor in.
Old Oct 22, 2017 | 06:05 PM
72rtchallenger's Avatar
72rtchallenger
I love c6 trannys , that being said I would use the 4spd of course thats a personal choice
Old Oct 22, 2017 | 09:54 PM
Fordv8'460's Avatar
Fordv8'460
The truck will be strictly for purpose. Will usually be hooked to a trailer of substantial weight. Which trans would better serve the purpose? All existing drivetrain is wired for the 4 speed but I know the c6 is bulletproof. What would be the most effective combination all things considered? All input is very much obliged.
Old Oct 28, 2017 | 12:36 PM
mark-guiver's Avatar
mark-guiver
The owner of the tow company I bought my new cab from told me they used to do that switch the time back in the day. They were using 1 ton duallys for tow trucks back then. He said they would take the 460 out of a wreaked Lincoln, pull the 390 and in a couple of hours be back on the road with the 460. He said the truck pulled better with the 460 and got a little bit better gas mileage. As far as the transmission, from your description of the intended use I would stick with the 4 speed. With the 6.69:1 1st gear I think that makes more sense. I like the C6 in my 75 but there are times I cant pull a steep hill from a dead stop when loaded heavily. I put it in low range and have no problem but, a lower 1st gear would be nice for those times.
Mark.
