Sponsored by: Real Truck
4R100 Torque Converter Interchange
Old Oct 19, 2017 | 02:15 PM
EstesTruck's Avatar
EstesTruck
Does anyone know if the Diesel 4R100 Torque Converter and the Gas 4R100 are interchangable??
Old Oct 19, 2017 | 02:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They are not.
The most obvious difference is that the diesel has six studs and the gas has four studs. The gas converters also have a higher stall speed than the diesel converters.
Will either one fit into the transmission? Yes, they will.
Old Oct 19, 2017 | 03:16 PM
EstesTruck's Avatar
EstesTruck
So the Diesel TC, though it would fit, would not bolt up to the gas flexplate? I'm just wondering if I could use the diesel version TC in my gas Trans to get the lower stall speed??
Old Oct 19, 2017 | 07:57 PM
Mark Kovalsky
If you drill the flex plate for six studs you could do that.
Old Oct 20, 2017 | 03:12 PM
EstesTruck's Avatar
EstesTruck
Mark, thanks for the feedback. The flexplate that I'm purchasing should have holes set up for 6 or 4 studs. So this should work. I guess my question should have been, "are the demensions the same?"
thor363
Jan 4, 2023 03:44 PM
351Cleveland C4
Jul 19, 2011 05:46 PM
Otto Square
Sep 25, 2009 09:25 PM
dieselturbo2000
Apr 12, 2009 01:13 PM
