What is the connector name/type/part number for the running lights connector (and many other connectors around the underside of the vehicle)? There are like a dozen connectors underneath the vehicle that aren't connected to anything. I'd like to find out what they go to and maybe get them connected to something appropriate.
for the speaker harness pictured earlier, but you will want to weatherproof them. I'm not familiar with the KR OEM harness, but that sounds like a good alternative since weatherproof connectors normally work well.
Just order the OEM harness for the KR running boards with the lights. Just a tad more in cost with weatherproof connectors and extra length.
Did some searching and couldn't find anything... care to provide a link? If all else fails, I suppose I could buy new 2 wire waterproof connectors and just snip off the factory ones...
That would be for 1(one) wire assembly, you need to order 2(two) total. They are long and will have the connectors on each end for a light bulb. I like the extra length since you can splice into the harness at any point you need to along the length.
Pretty sure I left the bulb holder ends on, then spliced in my puddle lights. Afterwards I found a set of KR running boards so I used my modded harness on those boards since I already had the puddle lights installed. Pretty sure the pull off harnesses are in the garage but that's a Bermuda Triangle for truck parts at the moment.
