69 f600
Old Oct 19, 2017 | 09:05 AM
f600bigred's Avatar
f600bigred
69 f600
I have had my truck for a few yeas now and its time to start repairs could someone brake down my vin# F61DED97247
Old Oct 19, 2017 | 07:35 PM
JEFFFAFA's Avatar
JEFFFAFA
Back then the vin number didn't tell much. All the other codes on that warranty plate told more.
F61...F600 gas 4X2.
D......330 H.D 2V carb
E.......built in Mahwah Assembly Plant
D97247....1969 model year.
Old Nov 7, 2017 | 08:02 AM
f600bigred's Avatar
f600bigred
Thanks for the info other questions on my truck is can I put electronic distributor in my 330 and get rid on the points also where can I find a rebuild kit for the carb
Old Nov 7, 2017 | 08:49 AM
FuzzFace2's Avatar
FuzzFace2
There is no need to replace the distributor if the bushings are good.
I am sure Pertronix makes a kit to replace the points and keep your distributor.
Check the carb for a tag with numbers or on the carb body for numbers. Take the numbers to a good parts store and they should be able to get you a kit.
Dave - - - -
Old Nov 12, 2017 | 10:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969 F600 330 2V H/D FT engine has a Holley 2V carburetor. The number on the carb ID tag will be necessary to get the correct kit, because there are two possible kits.
The triangular shaped carb ID tag is located on the air horn w/a screw. If it's missing (as usual), look on the base of the carb for the ID number, post what it is.
1972-34ton
Jul 6, 2015 07:29 PM
BlackLabel78
Mar 3, 2010 03:31 PM
civicmindeddogooder
13
Dec 9, 2009 12:51 PM
bnradams
Oct 18, 2009 12:58 PM
BuffDaddy
Apr 20, 2006 05:41 PM
