Hey guys finally built a new garage. I got the truck in and figured it's been sitting outside under a tarp outside for a bit. So decided to change the oil and start to get it ready to fire and looks like there is oil in the water. Am I correct and possible causes??
Thanks guys
Dan
Reason: Picture added
I’d change the oil and filter and run it a bit. Check the oil frequently. See if it clears the yuck out. If it’s condensation you may have to change the oil a couple of times. If it gets milky again you’re probably gonna have to pull the heads.
