Don't see a price. I was considering this approach - buying the parts.
But I eventually found a complete F250 but not running. the parts are not rusted like these sitting in piles. For $2500 got a 6L, trans, transfer case, seats, doors, seatbelts, FICM, 8 diesel fuel injectors, spare brake lights, 8' bed, etc, for my '98 F350 v10.
I am, but how are you planning on getting them to you once paid for? Also you do know they're EB seats right? Just making sure you noticed. Also thank Mecdac for texting me (late at night I might add!!!) and letting me know of your plight or I never would have seen this.
Good luck to anyone wanting it. I personally would opt for a turbo setup but we need to save this kit as they are getting kinda rare.
Don't tow with it if you get it. Seller told me the truck only had 109,000 miles on motor and head gasket blew out.
HE told me most parts are included so other than the upgrades needed to make the KB kit work "right" it is functional. I would add injectors, fuel pump, IAT sensor, Lightning maf, and a WB02.
iF it doesn't have aluminum lower intake I would pull one off a 99 V10.
Would probably need to have your pcm tuned to. Don't know if he has the KB PCM chip or not because it has a fmu instead of a boost a pump.
On edit: I bet he does not have a installation manual. If anyone buys it send me a PM and I can send you the install manual in pdf.
