4 link bars...trim?
Old Oct 16, 2017 | 08:26 AM
champipple's Avatar
champipple
4 link bars...trim?
wanting to shorten my bars on my 4 link to locate it inside the frame rails, rather than buy new bars, id like to cut the existing bars down. the bars one fixed end w/bushing the other is the threaded adjustable end.
thoughts on cutting the fixed end, shorten the bar 3-4" and attached the fixed end? is there a better way? Is this making the bar weaker in any way?
thanks
Old Oct 16, 2017 | 06:53 PM
Fauj's Avatar
Fauj
My advice would be to cut down the bars on the threaded end, measure the inside diameter and buy new threaded weld in bungs with the appropriate thread pitch. Then weld them in and be done.
Check
these these
out to see examples.
Jeff
Old Oct 16, 2017 | 07:38 PM
champipple's Avatar
champipple
awesome, thanks!
Old Oct 17, 2017 | 08:05 AM
willowbilly3's Avatar
willowbilly3
If it's just threaded inside the tube, why not just cut it off and have a machine shop cut new threads. Also I have done on tierods and such is cut the section out of the center and get a plug the right size to go inside and weld it back together. Get a plug about 3 inches long, leave a gap when you slide it together so the plug also gets welded at the butt weld but also drill a hole in each side to get a rosette weld inside to the plug. Finish it off with a flap wheel on the grinder and nobody will see it.
Old Oct 17, 2017 | 08:34 AM
champipple's Avatar
champipple
Great solution, I'm new at this obviously so asking for multiple ideas makes it easier!
Atwiss
24
Mar 25, 2011 11:32 AM
Point Blank
Mar 19, 2011 09:26 AM
ltbrkm3
Jan 18, 2009 07:55 PM
wilbur996
Oct 19, 2008 07:50 AM
moosed
Apr 5, 2008 05:51 PM
