Torque converter help.
Old Oct 15, 2017 | 07:25 AM
Liquid10Rider's Avatar
Liquid10Rider
Hey guys i just had my transmission rebuilt with a new torque converter as well but I believe that the converter is the wrong one. I went to go install it and noticed the TC is flat against the flywheel but there is still about a 1/4 gap around the bell housing. I checked to make sure the TC is fully seated on the shaft multiple times, but still no luck.
The part number is 2648ps Precision New Hampshire. I've looked it up and it looks like thats only for gas engines.
AJ
Old Oct 15, 2017 | 05:45 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
There are three things that must line up to be fully seated, but it sounds like you've got a good 3/4 inch left to go in.
Can't help with the part number, but good luck!
Old Oct 15, 2017 | 06:46 PM
bigb56's Avatar
bigb56
Did you stand the transmission up on it's tail when you installed the converter?
Old Oct 15, 2017 | 07:47 PM
Dan V's Avatar
Dan V
Have never in my life done that.
Old Oct 15, 2017 | 08:10 PM
bigb56's Avatar
bigb56
I always did, makes it easy to seat the converter. You can feel it just drop in once it is correctly aligned.
Old Oct 15, 2017 | 08:19 PM
bigb56's Avatar
bigb56
Here just so you don't think I'm nuts, step 7. If you don't have a helper a wall works pretty good.
Old Oct 16, 2017 | 04:36 AM
Liquid10Rider
When i slid the TC off of the shaft slightly, qnd pushed it back on i felt it go in once and than i turned it and it slid in more. Also i went on autozones website and put the part number in and added my truck and it says it doesnt fit tge 7.3 so i changed the engine to the 5.4 and it says it fits. Today ill call the rebuilder and ask again.
Old Oct 16, 2017 | 07:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The converter in a 5.4L and 7.3L are physically the same size. There are two differences.
The internal fins are different. This changes the stall speed, but in no way changes how it fits in the transmission. The other change is that the 5.4L has four studs to mount to the flex plate, the 7.3L has six studs.
If the torque converter isn't dropping into the trans three times it isn't all the way into the pump. If you bolt it to the engine without being fully seated in the pump you'll need to take it out again and replace the ruined torque converter and ruined pump.
Old Oct 16, 2017 | 07:52 AM
mueckster's Avatar
mueckster
Place a straight edge across the bell housing. There should be a gap between the crankshaft pilot hub and the straight edge.
Old Oct 16, 2017 | 08:48 AM
Dan V's Avatar
Dan V
I'm not saying you're wrong, I just saying that I've changed converters while the trans is still in frame. I guess you could stand the vehicle on end and do it, just that I don't have the ability to do that.
Old Oct 16, 2017 | 09:53 AM
Mark Kovalsky
The converter can be seated with putting the trans on end. It's just a lot easier to get it to drop in with the trans upright.
MinesRugger
22
May 4, 2020 01:13 PM
AK Cold
Aug 3, 2019 07:39 AM
Gigemags05
15
Oct 30, 2015 12:37 PM
JOHN2001
Jun 11, 2012 05:55 PM
stlrisk
Aug 6, 2010 05:29 AM
